Cat O & limited Cat I Hitches
/ Cat O & limited Cat I Hitches #1
tomnky
Platinum Member
Berea,Kentucky
Kubota BX2200
I know the pins are different but what else is different?
Does anyone have the exact dimensions to compare?
/ Cat O & limited Cat I Hitches #2
Re: Cat O & limited Cat I Hitches
Take a look here. Scroll to the bottom of the page for the specs.
3pt specs
Thanks Mad I appreciate the help as I had googled it but had no luck . Now all I need to know for sure is what is the vertical lift on the category O, as it didn't give that dimension.
The reason I ask is the Demco Sales Rep for Indiana is bringing a Sprayer to Louisville next week but it is a Category O and will need some alteration or bushings to work on My BX2200,if I decide to take it.
/ Cat O & limited Cat I Hitches #4
The mast height for Cat 0 is nominally 12 inches, but most manufacturers do not adhere carefully to that on either Category 0 or Category 1. If you have a 3 point implement that works for you now, measure the mast height to have a starting point to compare to.
JackIL
Thanks Jack.
I sure wish I could lay my hands on cat O easily to measure it.
ALUMINUM HEADACHE RACK (A63745)
ALUMINUM HEADACHE...
2016 GENERAC MMG025IF4-01 MOBILE POWER (A59910)
2016 GENERAC...
Great Plains UT5052 Vertical Tillage Tool (A63116)
Great Plains...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
28" X 60" STAINLESS STEEL TABLE (A63745)
28" X 60"...
(INOP) 1994 SEADOO BOMBARDIER XP JET SKI (A63745)
(INOP) 1994 SEADOO...
