3-Point Hitch Cat II to I back blade
   / Cat II to I back blade #1
wmaburnett
Hello everyone, thank for the advice on the tractor buying, I ended up with a good deal on a John Deere 730 diesel and now I am preparing for the winter season. I can稚 find a trip bucket loader so I have decided to go to a back blade, but I am having the hardest time finding a Cat II 3 pt. back blade for my tractor in the area, all I can find is fully hydraulic ones for 4,000. I was wondering if it would a good idea to Buy a Cat I back blade and put it on the tractor, I will only be using it for snow, and if It would work, would all i need to do is add some bushings to it or would I have to flip/take off the sway blocks and everything,
Thanks
~William
   / Cat II to I back blade #2
:welcome:
Where is "winter season" for you?
What have you used before to remove snow where you are at?
I gather you cannot find a FEL at all for the 730. That right?
I'd be looking at putting a regular snow plow blade like from a truck plow on before going the 3 ph blade on the rear.
   / Cat II to I back blade #3
Have you looked at new blades? There should be plenty of good cat 1-2 rear blades that are not hydraulic and I believe they cost in the neighborhood of $1500. Here's one to look at.
   / Cat II to I back blade #4
The 730 has got "lot's of iron" in the pants! :D I'd think with a bit of use.. that Cat I blade will be alot worse for the wear!
Your initial purchase money up front... might just end up being - "educational expenses"!
Keep lookin' for a good, Cat II blade.
AKfish
   / Cat II to I back blade #5
Might be hard to find in a non hydraulic version if shopping new, but that is a heavy tractor for sure and I would recommend looking for a blade rated for up to 100 hp.
UNUSED SET OF FUTURE 13', 200AMP JUMPER CABLES (A57192)
UNUSED SET OF...
(INOP) HYDREMA 912 HM ARTICULATED DUMP TRUCK (A52707)
(INOP) HYDREMA 912...
E-Z-Go Electric Utility Cart (A55851)
E-Z-Go Electric...
Kivel Quick Attach Forks (A56469)
Kivel Quick Attach...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
PULL BEHIND SHEEP FOOT COMPACTOR (A52707)
PULL BEHIND SHEEP...
