3-Point Hitch Cat II to I back blade
   / Cat II to I back blade #1
wmaburnett
Hello everyone, thank for the advice on the tractor buying, I ended up with a good deal on a John Deere 730 diesel and now I am preparing for the winter season. I can稚 find a trip bucket loader so I have decided to go to a back blade, but I am having the hardest time finding a Cat II 3 pt. back blade for my tractor in the area, all I can find is fully hydraulic ones for 4,000. I was wondering if it would a good idea to Buy a Cat I back blade and put it on the tractor, I will only be using it for snow, and if It would work, would all i need to do is add some bushings to it or would I have to flip/take off the sway blocks and everything,
Thanks
~William
   / Cat II to I back blade #2
:welcome:
Where is "winter season" for you?
What have you used before to remove snow where you are at?
I gather you cannot find a FEL at all for the 730. That right?
I'd be looking at putting a regular snow plow blade like from a truck plow on before going the 3 ph blade on the rear.
   / Cat II to I back blade #3
Have you looked at new blades? There should be plenty of good cat 1-2 rear blades that are not hydraulic and I believe they cost in the neighborhood of $1500. Here's one to look at.
   / Cat II to I back blade #4
The 730 has got "lot's of iron" in the pants! :D I'd think with a bit of use.. that Cat I blade will be alot worse for the wear!
Your initial purchase money up front... might just end up being - "educational expenses"!
Keep lookin' for a good, Cat II blade.
AKfish
   / Cat II to I back blade #5
Might be hard to find in a non hydraulic version if shopping new, but that is a heavy tractor for sure and I would recommend looking for a blade rated for up to 100 hp.
EZ-GO Golf Cart (A56469)
EZ-GO Golf Cart...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
(INOP) HYDREMA 912 HM ARTICULATED DUMP TRUCK (A52707)
(INOP) HYDREMA 912...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2019 Kubota SVL75-2 (A53317)
2019 Kubota...
