CAT II Ballast box (3) questions
   / CAT II Ballast box (3) questions #1
Zebrafive
Super Member
South West MI
John Deere 2030, John Deere 6415
I am going to build a CAT II ballast box.
How High should I locate the center of the top link pin hole above the box so it will still work with a quick hitch? I plan to weld the bracket inside the box on what will be the side closest to the tractor.
What should the vertical centers be between the lower pins and top lin pin hole? Again so it will work with a quick hitch (a quick hitch is on my wish list I do not have yet)
Plan is to make it 32" wide and drill holes in the sides for the lower pins. Will this width work with a quick hitch?
Searching I found Cat II quick hitches are 32 3/4" between the lower hooks and 15" center to center upper to lower pins.
2022 Ram Bighorn 2500 4X4 (A51039)
2022 Ram Bighorn...
3in Poly Pipe (A49461)
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A51039)
2000 John Deere...
16ft Trailer (A50322)
2006 Pearson Quantum Fire Truck (A50323)
2006 Pearson...
International 133 6 Row Cultivator (A50514)
International 133...
