CAT II Ballast box (3) questions
   / CAT II Ballast box (3) questions #1
Zebrafive
Super Member
South West MI
John Deere 2030, John Deere 6415
I am going to build a CAT II ballast box.
How High should I locate the center of the top link pin hole above the box so it will still work with a quick hitch? I plan to weld the bracket inside the box on what will be the side closest to the tractor.
What should the vertical centers be between the lower pins and top lin pin hole? Again so it will work with a quick hitch (a quick hitch is on my wish list I do not have yet)
Plan is to make it 32" wide and drill holes in the sides for the lower pins. Will this width work with a quick hitch?
Searching I found Cat II quick hitches are 32 3/4" between the lower hooks and 15" center to center upper to lower pins.
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
2022 Ford F-550 XL Crew Cab Forestry Chipper Truck (A49461)
2022 Ford F-550 XL...
2019 Kubota F3990 72 in. Commercial Mower (A50324)
2019 Kubota F3990...
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50775)
UPDATED INTERNET...
