CAT I
/ CAT I #1
EasyE
North Carolina
JD 2305
I am new to tractors, only had my JD2305 since December. I understand from my manual my tractor is a CAT I as far as the three point hitch, this I understand but, what does CAT I mean? I assume there are CAT II's and CAT III's? Can you folks give me a better understanding of this so when I go to buy attatchments I know something about what I am buying?
/ CAT I #3
This might help you...
basically, the difference between the categories is the upper and lower link pin diameters and spacing.
You'll need Adobe Acrobat Reader (free download) or another PDF file reader to view this...
  • 830591-3 Point Hitch Data.pdf
/ CAT I #5
The sites that Brian and Roy posted gave some of the specs. There are also specific distances between the two lower pins and the upper pin. Typically the smaller sizes (0, 1) are not adhered too very well by many manufactures. As you get in the larger sizes (2, 3, 3N), most manufactures adhered to sizes pretty well. The sizes are Cat. 0, 1, 2, 3 and 3 narrow.
/ CAT I #6
Here is a site that gives plenty of info on 3pt hitch types. A dimension chart is at the bottom of the page.
3pt hitch types
/ CAT I #7
I would like to add that there is another category that few have heard of, and that is, CAT 1N. It is identical to the standard CAT 1 except the lower pin spacing, shoulder to shoulder, is 20" instead of 26". The Kubota BX series will use this spacing much better than the standard CAT 1 as well as the New Holland TZ, the Massey Ferguson GC. and the John Deere 2305, 2210 etc., subcompacts can use the standard CAT 1 however I sell a ton of our Handi Hitches in the narrow version, CAT 1N, specifically for these sub-compacts. Even though all the major manufacturers advertise their subcompacts as CAT 1, you should phisically hold the lift arms 26" apart and look at your tire clearance. Depending on whether you are running ag tires or turf tires, if you don't keep the sway chains tight you could easily have your lift arms rubbing on the tires on some of these tractors. Hope this helps.
1998 Toro Groundsmaster 223D 52in. Commercial Riding Mower (A64194)
1998 Toro...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
2021 Weber CF 2-IIHD Plate Compactor (A61572)
2021 Weber CF...
2023 Chevrolet Express 2500 Cargo Van (A61573)
2023 Chevrolet...
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
2002 INTERNATIONAL 4300 S/A (A67148)
2002 INTERNATIONAL...
