Cat 950B wheel loader
/ Cat 950B wheel loader #1
Rickj1972
950B cat wheel loader
Why is it pushing all the oil out the vent tube
On the gear box
/ Cat 950B wheel loader #3
Gonna need a lot more info. What conditions does this happen? Assume correct fluid levels? Does the loader have all gears and power in each? Does it do it only when hot, pushing hard or all the time? When was it serviced last?
My first thoughts are - overfilled, overheated, or a clogged passage/filter.
My fathers was a D (I think) and if I recall correctly had an air over hydraulic brake system and trans disconnect. Air pressure was required to shift. We had troubles with the air brakes all of the time (not uncommon) which seemed to lead to the loss of gears. For many years we ran it with 2nd gear only until that finally gave out too. Rebuilt to the tune of $25k.
Allis Chalmers WD45 (A66285)
Allis Chalmers...
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
2000 Artic Cat ZR600 Limited Edition Snow Mobile (A62613)
2000 Artic Cat...
PORTER CABLE AIR COMPRESSOR (A65643)
PORTER CABLE AIR...
2016 Boxer 700HDX Compact Skid Steer (A63109)
2016 Boxer 700HDX...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
