Cat 1 quick hitch and HP rating
/ Cat 1 quick hitch and HP rating #1
tsmithco
Bronze Member
SW Ohio
2015 Kubota L5740
I was looking at quick hitches, and rural king, tractor supply, and harbor freight all say "for tractors no more than 45 HP" fro the cat 1 hitches.
Why?
I have 2 tractors - New Holland TC33d (33hp), and a Kubota L5740 (57hp).
All my attachments are cat1.
- box scaper
- 84" flail mower
- TR3-E arena drag
Would the hitch be a bad idea?
/ Cat 1 quick hitch and HP rating #2
Not sure about the NH but the Kubota is probably a CAT I/II so it has CAT I size for versatility. Real CAT I implements are generally built for 20-50 HP machines so TSC is probably just padding for their warranties etc. And if TSC says don't use it for over 45 HP that probably means less than 30 HP IMHO.
/ Cat 1 quick hitch and HP rating #3
It's most likely a CYA thing. If you run a more powerful tractor and the hitch or implement breaks it's on you. I suspect it has something to do with our sue crazy environment today.
/ Cat 1 quick hitch and HP rating #4
I doubt it would matter much at all unless you're hooked to something ground engaging and pulling hard, like a mold board plow or bigger disk.
They're probably worried you'd pull it apart if you hooked a rock with a plow or middle buster.
What are you going to connect to it? If it's only the 3 attachments you have listed, I wouldn't worry about it.
Thanks all.. Yeah, nothing crazy, just those attachments. no plowing dirt or anything like that.
