Caster Wheel Attached To Rear Of Skidsteer?
   / Caster Wheel Attached To Rear Of Skidsteer? #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
Until recently I had not seen a caster wheel mounted to the back of a skidsteer. I'm under the impression that they are used to take weight off of the two rear tires of the skidsteer.
Anyone familiar with this? Pics?
   / Caster Wheel Attached To Rear Of Skidsteer? #2
I’ve never seen one. Are you sure it wasn’t a homemade job for a unique job? It seems like a terrible idea for regular work.
   / Caster Wheel Attached To Rear Of Skidsteer? #3
Might be so it can turn very sharply without skidding, like a 3-wheel forklift, or one of these.
Turning sharply without ground damage may be more important than 4-wheel drive.
Bruce
   / Caster Wheel Attached To Rear Of Skidsteer? #5
Bruce
That looks like a similar concept as the 3 wheeled delivery forklifts. The fourth post here looks like a more promising concept. I was envisioning something permanently mounted sticking down on the back of a skid steer.
   / Caster Wheel Attached To Rear Of Skidsteer? #6
Quite a few commercial beekeepers use them. Like bcp said, sharp turns with less ground damage.
Sounds like someone needs to design a skid steer that converts between 2WD and 4WD and let's the two rear wheels caster in 2WD.
Bet that would be a challenge.
Close enough for me. That is awesome!
UNUSED Black Steel Diamond Plate (A50860)
UNUSED Black Steel...
2011 Clarke JU4H-UFE0 4 in. Water Pump (A50860)
2011 Clarke...
Desk (A50860)
Desk (A50860)
Lot of 2 2017 Stihl TS800-16 Concrete Saws (A48083)
Lot of 2 2017...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A50397)
2024 BCL...
2011 Ford Ranger Pickup Truck (A50323)
2011 Ford Ranger...
