Caster Wheel Attached To Rear Of Skidsteer?
   / Caster Wheel Attached To Rear Of Skidsteer? #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
Until recently I had not seen a caster wheel mounted to the back of a skidsteer. I'm under the impression that they are used to take weight off of the two rear tires of the skidsteer.
Anyone familiar with this? Pics?
   / Caster Wheel Attached To Rear Of Skidsteer? #2
I’ve never seen one. Are you sure it wasn’t a homemade job for a unique job? It seems like a terrible idea for regular work.
   / Caster Wheel Attached To Rear Of Skidsteer? #3
Might be so it can turn very sharply without skidding, like a 3-wheel forklift, or one of these.
Turning sharply without ground damage may be more important than 4-wheel drive.
Bruce
   / Caster Wheel Attached To Rear Of Skidsteer? #5
Bruce
That looks like a similar concept as the 3 wheeled delivery forklifts. The fourth post here looks like a more promising concept. I was envisioning something permanently mounted sticking down on the back of a skid steer.
   / Caster Wheel Attached To Rear Of Skidsteer? #6
Quite a few commercial beekeepers use them. Like bcp said, sharp turns with less ground damage.
Sounds like someone needs to design a skid steer that converts between 2WD and 4WD and let's the two rear wheels caster in 2WD.
Bet that would be a challenge.
Close enough for me. That is awesome!
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
New Holland TS100 Tractor (RIDE AND DRIVE) (A50774)
New Holland TS100...
CATERPILLAR VC60DSA SHOP FORKLIFT (A52472)
CATERPILLAR...
2017 Ford F-650 Mason Dump Truck (A50323)
2017 Ford F-650...
