Cast Iron
/ Cast Iron #21
Adding a loader and/or a backhoe typically requires the use of a steel underframe for increased structural support. Since these addons are so common, why not eliminate the need for an underframe by making the tractor itself stronger in the first place?
G'day this would push the price up and the manufacturer is not going to absorb it , it will prob make the machine 3 times heavier than it is now, there for increasing transport costs, all this adds up to a dearer end product which makes it harder to sell. How many of you have bought a machine where price was a considering factor? Also how many have bought the tractor and later on bought a b/h unit to go on it ? Did you ask the dealer at the time would the machine handle these add ons? Yes I know there are alot of units out there with these add ons and have had no probs but do they shift a ton of dirt a day or a year? There are alot of cheap imports coming in over here now and the people selling them don't care about your machine all they see is the $$$ signs so they are not going to tell you to fit a subframe ( most prob don't even know what one is:confused2:) unless it is something they can sell you too.
All in all from what I have read on here I think that some of the failures were not down to the machine being at fault.
Bottom line is manufacturers are not going to make them heavier and miss out on sales because their machine is now $2k dearer than the opposition
Ranting is finished now
Jon
/ Cast Iron
Then the is the issue of faulty castings and safety margin used to design and make the castings. i mention them together because bigger saftey margin allows more internal flaws w/o failure. Increasing either better casting process or safety margin costs more. Does that answer your question?
I agree that reduced manufacturing costs are the most likely reason for the frameless design. However, it seems to me that any savings that were gained, are lost when taking into account the need for additional support for loaders and backhoes.
My thinking is that with the higher cost of having to use an underframe, that the increased cost of making the frameless design stronger would be mitigated.
Curiously, it appears that the first farm tractors did indeed use a steel frame, prior to the introduction of the frameless design, which dates back to 1913 with the introduction of the Wallis Cub tractor. The website below gives an interesting glimpse into the early history of farm tractors.
Farm Tractors
/ Cast Iron #23
You should consider that some tractors do break (for whatever reason), but the vast majority of tractors do not break and may last decades.
As far as why use cast iron and steel...intricate shapes at the lowest cost.
/ Cast Iron
I'm not trying to say that the frameless design is bad or that all tractors are likely to break. I simply like to think outside of the box and tend to not follow the status quo. As a result, I tend to question things, regardless of how long they may have been successfully utilized.
/ Cast Iron #25
Roy, they closed IH here in Mem in 1981. Ths foundry poured Mailiable iron and doctile iron..The cast iron formed from some of the same ingredients as it cooled and or poured too late??Few parts were made there from cast iron..I have to say the breaking of modern tractors seem to be from stress of missing bolts and or other forces as in abused loaders. I did hear of my neighbor pulling his JD 4020, into as he force pulled it out of a hole?I do admit to being prejudice to the mystery iron or metal from some of the third world countrys? But a tractor of steel, maybe a frame??
/ Cast Iron
Come to think of it, this could very well be a contributing factor to weakness in some (not all) newer tractors that are imported or manufactured from imported parts.
It's well kown that products manufactured in certain foregin countries tend to have a lot of flaws so it's reasonable to assume that the quality of the metal or "unobtanium", would suffer from similar problems, likely caused by impurities introduced during the manufacturing process itself.
/ Cast Iron #27
I think some people need to educate themselves about the different types of cast iron and their properties.
Making something out of steel is no guarantee that the part will be stronger than a cast piece on an equal cost per piece basis.
The problem of cast iron failing isn't one of material choice, it's one of engineering to maximize profits. The closer you get to "just strong enough" for the intended purpose, the greater are the chances for a failure happening. This is true in everything.
/ Cast Iron
That is the whole point of this thread, to learn.
There are no guarantees for anything in life.
As I've stated, I believe cost is the driving force behind the manufacturing methods being used. However, both material choice and thickness are part of the engineering process that can greatly affect the structural limitations of any design. In other words, as they make them cheaper by using poor quality materials and/or using less material, the strength of the design can easily become weaker as a result.
/ Cast Iron #29
The Power Trac tractors are made out of steel plate and are designed accordingly. But they are also not making 10,000 of them.
Ken
/ Cast Iron #30
Ken
You can only make money off castings if you make a lot of them...otherwise, it's cheaper to fabricate.
Low volume casting runs are quite expensive and the scrap rate can be high (takes a while before the process is tweaked).
/ Cast Iron #31
After reading about tractors that have broke in half at or near the bell housing, which is typically made of cast iron or some other unobtanium material, I couldn't help but wonder why it is used instead of steel.
Cast iron is a very strong metal but it is brittle and can crack or break without warning, as evidenced by some tractors breaking in half. Also, cast iron is difficult to weld, thus making repairs impractiical or impossible.
I am no metallurgist but it seems to me that steel would be a much better material to use. Steel is very strong, more flexible, and can be easily welded, thus making repairs much easier.
Engine blocks I can understand, but why do tractor manufacturers use cast iron instead of steel for bellhousings, axles, and other components?
You are right. They don't. Most of what is called "cast iron" is actually cast alloy steel. Like anything else, casting quality can vary. But cast steel alloy is basically a good tough material. All cast materials are difficult to weld. It isn't just a case of steel versus iron. One big difference is whether the metal is rolled, formed, hammered and hot-worked as is the case with most structural steel shapes....or just left to cool slowly as an alloy steel casting.
So the things you describe are due to what it's made of, it's how it's made.
enjoy, rScotty
/ Cast Iron #32
G'day this would push the price up and the manufacturer is not going to absorb it , it will prob make the machine 3 times heavier than it is now, there for increasing transport costs, all this adds up to a dearer end product which makes it harder to sell. Bottom line is manufacturers are not going to make them heavier and miss out on sales because their machine is now $2k dearer than the opposition
Jon
Right. Except by extent. It wouldnt take much extra material for the strength needed if that material was incorporated in the right places. A couple hundred pounds in the right places would suffice even on a pretty good sized tractor. New design and moulding would be expensive and would be a killer for those companies running "new" tractors from old design molds. ... Now if a design was starting from scratch, design of castings for enhanced durability under greater stresses would make it very cost effective and a selling point for the nominal extra sticker price. The benefits I see would be more and low CG weight, strength to make bracing unecessary thereby saving money and ground clearance with attachments, cleaner underside for servicing, etc.
larry
/ Cast Iron #33
Most of what is called "cast iron" is actually cast alloy steel. rScotty
Just curious why do you say that? Last time I looked at cast iron under the microscope, it did not not look anything like steel :D
/ Cast Iron #34
Again, I'm no metallurgist and I'm not trying to reinvent the wheel. I'm just curious if there might be a better way.
Of course there is. problem is the bean counters or YOUR wallet that keeps bring us back to cast iron.
/ Cast Iron #35
I think masseywv is missing the point of a tractor . A tractor is intended to pull implements from the the draw bar or the three point. loaders , backhoes ect are all options that are like an after thought . we turn them into swiss army knifes. if you realy want a loader you buy a deadected wheel loader or if you want to excavate you buy an excavater. if the mfg were building tlbs they would use a fabricated steel frame not a cast frame. the cost of tractor that was desined to have a loader/hoe installed permanetly would be much too high for most buyers. my .02 cents
9
/ Cast Iron #36
I think masseywv is missing the point of a tractor . A tractor is intended to pull implements from the the draw bar or the three point. loaders , backhoes etc are all options that are like an after thought . we turn them into swiss army knifes. if you really want a loader you buy a dedicated wheel loader or if you want to excavate you buy an excavator. if the mfg were building TLBs they would use a fabricated steel frame not a cast frame. the cost of tractor that was destined to have a loader/hoe installed permanently would be much too high for most buyers. my .02 cents
Good points...
/ Cast Iron #37
Somebody said that cast iron and cast steel are equally easy to pour, but that is not true. Cast iron has a lower melting point and flows through a mold better. Cast iron has improved vibration damping characteristics and is much more rust resistant than steel. It also has excellent abrasion resistance. But it does have more than 2% carbon and in standard grey iron the carbon is in flakes. The points on those flakes are stress risers so it is not at all ductile.
Nearly all the large steel castings with which I have worked have had foundry weld repair - surface voids and porosity. Appearance is also not as good as a grey iron casting. The foundry people tell me it is due to the higher pour temperature.
But sometimes you need the strength of steel, and especially all the alloys that are then available. And of course you can weld to steel. On large frames in Cat equipment we use castings for complex corners and then weld straight frame rails to the corner castings.
Cast iron makes a good engines and transmission housing because of its vibration damping, its machinability, and the fact that you can cast in a lot of ribs for stiffness. The last think you want your engine or transmission doing is deflecting a large amount under load throwing your bearings out of alignment.
/ Cast Iron #38
would you pay 40k$ for a tractor that could otherwise be sold for 20k$
think of the process involved in making the the entire machine from steel.
look at heavy equipment.. lots of steel.. almost no cast except the engine.
then look at the price tag of that yellow iron...
people wouldn't buy it enmasse. thus there's little market for it.. not to mention the $difficulty$ in mass producing it.
soundguy
/ Cast Iron #39
Doesn't cast iron get harder with age? Carbon percipitating out at grain boundaries??:confused:
Seems I heard that Rolls Royce used to cure/age their cast iron cylinder blocks??:confused:
/ Cast Iron #40
Old timers would age cast iron castings for years. Had as much to do with stresses from casting as anything else. As cast structure has a lot of stress and machining will warp the castings. A stress relieving heat treat will accomplish the same thing in less time.
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2019 Nissan Sentra Sedan (A61574)
2019 Nissan Sentra...
12ft S/A Utility Trailer (A61574)
12ft S/A Utility...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63688)
2006 Cadillac GM...
2017 Takeuchi TL10V2 High Flow Compact Track Loader Skid Steer (A61572)
2017 Takeuchi...
