Caseih Farmall 50A
/ Caseih Farmall 50A #1
Danto
Caseih Farmall 50A
I recently bought a new Farmall 50A tractor. It is a 2 wheel drive, no loader as I needed it as a haying tractor. I have a couple of questions. First, it has a gear noise (Trans or rear end?) that seems quite loud too me. It is louder in reverse. I've talked to the dealer, and he said as long as the oil is at the proper mark (and it is) on the dip stick to run it. Just wondering if anyone else with a tractor like this has noticed this problem. Secondly, when I first got it, I filled it with diesel, and ran it about 20 hours or so, and the fuel gauge did not drop at all. Removed the filler cap and there was a strong vacuum. Then the gauge registered about 1/3 or so. Is it normal for there to be a vacuum when the cap is removed? Oh one other thing, the speedometer registers in km/hr and I need mph. Can I change that or does the dealer need to hook a computer to it to change that. Other wise, it seems like it is going to be a good tractor. I did hook it to a 6 ft bush hog and cut some high, thick grass and it handled it good.
/ Caseih Farmall 50A #2
Had the same tractor and sold it a few years back. Was a great hay tractor and I never had any of the issues you described. Only problems were the starter went out around 200 hours and the neutral position sensor failed around 250 hours. Otherwise it ran strong for us for quite a few years before and after those problems
/ Caseih Farmall 50A #3
I have seen mud daubers get in the fuel tank vent lines and plug them off.
When that happens all sorts of strange things happen.
Hay Feeder (A65640)
Hay Feeder (A65640)
2002 International School Bus (A64194)
2002 International...
2007 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2007 INTERNATIONAL...
New/Unused CFG Industrial NT18K Mini Excavator (A65583)
New/Unused CFG...
2021 Caterpillar 279D3 Compact Track Loader Skid Steer (A64553)
2021 Caterpillar...
2024 Ford Explorer SUV (A61574)
2024 Ford Explorer...
