Case VAC Problems
   / Case VAC Problems #1
mhachez
Ontario
Case VAC 14
Hi,
While working with my VAC 14, I noticed that it wasn't working properly. I then decided to check the oil and found some antifreeze and also it sounded like the motor was only running on 3 cylinders instead of 4 but it never had smoke coming out of exhaust.
As I started to drain the oil, I noticed that there was some pieces of the bottom part of the piston. It looks like only one piston blew.
Does anyone know what could cause the bottom of the piston to blow up like that? Any suggestion?
   / Case VAC Problems #2
Is their suppose to be power on both sides of the coil?
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
434669 (A48836)
434669 (A48836)
2009 Ford Flex SE SUV (A50324)
2009 Ford Flex SE...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
