case vac keep breaking dist. drive gear pin
/ case vac keep breaking dist. drive gear pin #1
big dynasty
case vac /massey harris 44
I have replaced the drive gear pin 3 times it will run for a while then it breaks
what might cause this problem
/ case vac keep breaking dist. drive gear pin #2
Sounds like you have a lot of end play in the camshaft or a lot of play in the dist. shaft
/ case vac keep breaking dist. drive gear pin #3
Might try pulling the Distributor shaft out of the Disttributor and clean and oil the bushings and shaft.
2021 JOHN DEERE 331G SKID STEER (A62129)
2021 JOHN DEERE...
John Deere Z994R (A60462)
John Deere Z994R...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
Lot of Allmand Light Plant Fixtures - Halide Assemblies (Bulk Lot) (A63689)
Lot of Allmand...
2014 International DuraStar 4300 S/A Dump Truck (A61573)
2014 International...
2009 Ford E-350 Cargo Van (A61573)
2009 Ford E-350...
