CASE MAGNUM 275 OIL COOLER PROBLEMS
   / CASE MAGNUM 275 OIL COOLER PROBLEMS #1
kirky
new zealand
case magnum 275
Hey guy,
I have a Magnum 275 and gone through 3 oil coolers in the last 3 weeks, keeps blowing out at the inlet at the top, tested the pressure it was doing 200psi... dont know if thats too high whats the recommended psi for an oil cooler?? Fairly urgent.
Cheers appreciate any help
   / CASE MAGNUM 275 OIL COOLER PROBLEMS #2
The oil psi was 200? One would think it should be 25 t0 80! But I don't know!
   / CASE MAGNUM 275 OIL COOLER PROBLEMS #3
G'day Kirky are you talking engine oil cooler or trans/hyd cooler? If it is engine then it is way too high 40-60 would be more like it if it is hyd cooler then it may be right, but I am used to seeing those coolers on a bypass circuit that usually top out at 30-40 psi there may be a regulating valve that is jammed. Sorry but I am not up with the system in your machine hopefully someone can pitch in or you get yourself a workshop manual on it.
Good luck
Jon
New/Unused AGT MX-CRT23 Mini Skid Steer Loader (A51573)
New/Unused AGT...
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
2016 Arising 8.520VTRW 22ft T/A Enclosed Cargo Trailer (A51694)
2016 Arising...
2019 Nissan Sentra SV Sedan (A51694)
2019 Nissan Sentra...
2007 International 4300 Box Truck, VIN # 1HTMMAAL07H360176 (A51572)
2007 International...
RoGator RG1100C (A53472)
RoGator RG1100C...
