Case JX80 losing fuel to injectors
   / Case JX80 losing fuel to injectors #1
matyou1
Triadelphia
Case JX80
Any idea on why the JX80 would be losing it's fuel to the injectors while operating? This happened with 1/4 tank of fuel and 3/4 tank of fuel.
Thank you.
Matt
   / Case JX80 losing fuel to injectors #2
Hi welcome to TBN.
I think we need more information. What do you mean by losing fuel to the injectors? Is fuel leaking out or are the injectors not getting fuel?
   / Case JX80 losing fuel to injectors #3
Welcome to the forum! :welcome:
I'm going to move your thread on over to the Case section.
   / Case JX80 losing fuel to injectors #4
Check the banjo fittings on the fuel line connections between the tank and filters. pay particular attention to the first fitting downstream from the tank. Check both the bolt and the barb of the fitting for accumulated debris.
Originally thought I was not getting fuel to the injectors, now it seems to be drawing air from somewhere. I will check banjo fittings and etc. After bleeding out the air the tractor has been running, but I have noticed a drop in the rpm while under load a couple of times.
Thanks for the suggestions.
2021 JOHN DEERE CP690 LOT IDENTIFIER 182 (A53084)
2021 JOHN DEERE...
2001 Ford F150 (A50121)
2001 Ford F150...
2012 JOHN DEERE 410K BACKHOE (A51246)
2012 JOHN DEERE...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2014 DIAMOND C TRAILER MFG. (A50322)
2014 DIAMOND C...
