Case JX80 losing fuel to injectors
   / Case JX80 losing fuel to injectors #1
matyou1
Triadelphia
Case JX80
Any idea on why the JX80 would be losing it's fuel to the injectors while operating? This happened with 1/4 tank of fuel and 3/4 tank of fuel.
Thank you.
Matt
   / Case JX80 losing fuel to injectors #2
Hi welcome to TBN.
I think we need more information. What do you mean by losing fuel to the injectors? Is fuel leaking out or are the injectors not getting fuel?
   / Case JX80 losing fuel to injectors #3
Welcome to the forum! :welcome:
I'm going to move your thread on over to the Case section.
   / Case JX80 losing fuel to injectors #4
Check the banjo fittings on the fuel line connections between the tank and filters. pay particular attention to the first fitting downstream from the tank. Check both the bolt and the barb of the fitting for accumulated debris.
Originally thought I was not getting fuel to the injectors, now it seems to be drawing air from somewhere. I will check banjo fittings and etc. After bleeding out the air the tractor has been running, but I have noticed a drop in the rpm while under load a couple of times.
Thanks for the suggestions.
2016 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51246)
2016 CATERPILLAR...
2000 GMC C7500 Flatbed Truck, VIN # 1GDM7H1C4YJ505285 (A51572)
2000 GMC C7500...
16ft 3in Box Blade (A51573)
16ft 3in Box Blade...
2005 Mack CV713 Granite Truck, VIN # 1M2AG11C55M020965 (A51572)
2005 Mack CV713...
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
2006 Husqvarna YTH2148B 48in Riding Mower (A51694)
2006 Husqvarna...
