Case IH D40 temp gauge install
/ Case IH D40 temp gauge install #1
Big_Lug
Jennings,LA
Case IH D40
If anyone can reply it would sure be appreciated, how hard is it to install a factory original temp gauge for a D40. This tractor does not come with a gauge, just an idiot light, and I know I have to install the gauge in the instrument cluster, but the kicker is how do you wire it up? Just need a little explanation of this. Thanks to whoever responds.
/ Case IH D40 temp gauge install #2
It's possible the wiring is already in place. You'll likely need a new sending unit that will work with the gauge. I have a shop manual,I'll try to look tomorrow for some info.
/ Case IH D40 temp gauge install #3
Most gauges will include a sending unit with them. ALl you wil really need is a power source that is triggered by the ignition and a good ground.
1991 BMY 6x6 Wrecker (M936A2) (A62613)
1991 BMY 6x6...
Oxy-acetylene Torch and Regulator Rig (A63118)
Oxy-acetylene...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
ALLEN AR16 BUGGY (A63569)
ALLEN AR16 BUGGY...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
Case Axial-Flow Combine Wheels NO RESERVE (A63118)
Case Axial-Flow...
