Case IH 585 where to hook up hydraulic spool valve
   / Case IH 585 where to hook up hydraulic spool valve #1
iampbdb
Granger, IN
Case IH
I am adding a two spool valve to my Case IH 585 and need to know where to tap into the hydraulic system to attach the supply and return for my new valve.
Thanks.
   / Case IH 585 where to hook up hydraulic spool valve #2
From the factory they added a power beyond port to the side of the transmission to feed from. Might be best to look in a bone yard on a 20 plus year old tractor. There were serial number breaks on some!
Here are some pictures. Maybe someone will recognize where to hook up the 2 spool valve
   / Case IH 585 where to hook up hydraulic spool valve #4
The power beyond port bolts onto the valve you have pictured. They were by serial number as to what fit which tractor so beware that you are getting the right one. Most all loader tractors where hooked up with them.
Rears 500 Gallon Orchard Sprayer (A50120)
Rears 500 Gallon...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
John Deere 400 Rotary Hoe (A50514)
John Deere 400...
JMR 40" Mini Root Grapple (A50121)
JMR 40" Mini Root...
2003 VIKING  CEMENT MIXING TRAILER (A52472)
2003 VIKING...
3 pt Post Hole Digger (A50515)
3 pt Post Hole...
