Case IH 585 where to hook up hydraulic spool valve
   / Case IH 585 where to hook up hydraulic spool valve #1
iampbdb
Granger, IN
Case IH
I am adding a two spool valve to my Case IH 585 and need to know where to tap into the hydraulic system to attach the supply and return for my new valve.
Thanks.
   / Case IH 585 where to hook up hydraulic spool valve #2
From the factory they added a power beyond port to the side of the transmission to feed from. Might be best to look in a bone yard on a 20 plus year old tractor. There were serial number breaks on some!
Here are some pictures. Maybe someone will recognize where to hook up the 2 spool valve
   / Case IH 585 where to hook up hydraulic spool valve #4
The power beyond port bolts onto the valve you have pictured. They were by serial number as to what fit which tractor so beware that you are getting the right one. Most all loader tractors where hooked up with them.
Black Max 2.3GPM Portable Pressure Washer (A55787)
Black Max 2.3GPM...
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
Kawasaki NR (A50324)
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2019 FREIGHTLINER...
