Case IH 585 where to hook up hydraulic spool valve
   / Case IH 585 where to hook up hydraulic spool valve #1
iampbdb
Granger, IN
Case IH
I am adding a two spool valve to my Case IH 585 and need to know where to tap into the hydraulic system to attach the supply and return for my new valve.
Thanks.
   / Case IH 585 where to hook up hydraulic spool valve #2
From the factory they added a power beyond port to the side of the transmission to feed from. Might be best to look in a bone yard on a 20 plus year old tractor. There were serial number breaks on some!
Here are some pictures. Maybe someone will recognize where to hook up the 2 spool valve
   / Case IH 585 where to hook up hydraulic spool valve #4
The power beyond port bolts onto the valve you have pictured. They were by serial number as to what fit which tractor so beware that you are getting the right one. Most all loader tractors where hooked up with them.
1986 ASPT 30ft S/A Pole Trailer (A49346)
1986 ASPT 30ft S/A...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A51039)
2-Row Peanut...
TAKEUCHI TB210R EXCAVATOR (A51242)
TAKEUCHI TB210R...
2006 INTERNATIONAL PAYSTAR 5500I KILL TRUCK (A50854)
2006 INTERNATIONAL...
2004 Dodge Dakota Ext. Cab Pickup Truck (A50323)
2004 Dodge Dakota...
