Case IH 485 Clutch Issue??
   / Case IH 485 Clutch Issue??
What is a ballpark range for a mechanic to replace the clutch?
   / Case IH 485 Clutch Issue?? #12
For 485, depends on the model and configuration, a 2wd with no loader or cab could be less than a day in shop start to finish, 4wd with (aftermarket) cab and loader add a bunch of time.
2wd
I took the loader off
   / Case IH 485 Clutch Issue?? #14
2wd
If you've got the loader (and mounting brackets) off you're set up right you could probably have it split in less than two hours. Rest of the time getting old clutch assembly replaced and flywheel done if needed.
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A56857)
2017 Kawasaki Mule...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A56858)
2007 Western Star...
Hyundai HL 960 Wheel Loader (A56857)
Hyundai HL 960...
2011 Ford F-150 Ext. Cab Pickup Truck (A55973)
2011 Ford F-150...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A56435)
2022 Schulte...
2015 UTILITY VS2RA 53FT REEFER TRAILER (A58018)
2015 UTILITY VS2RA...
