Case ih 385 loader won't lift
   / Case ih 385 loader won't lift #1
bigred 01
wausau
case ih 385
I have a 1987 Case ih 385 with a 594 allied loader.
after the tractor warms up I lose my lift on the loader I still have down pressure, and I can dump the bucket.
The three point arms also works, the steering works but makes noise.
   / Case ih 385 loader won't lift #2
Install a gage and check the pressure.
Does you valve relief ever activate?
Can you raise the front wheels off the ground?
Is the spring centering on the valve working correctly. Sometimes the nut backs off the spring.
yes I can raise the front wheels off the ground with both the arms and the bucket.
the joystick for the loader just seems to go dead in the lift position after the tractor warms up.
the tractor started having the loader problem after I had run brushog on 3 point for 3 or 4 hours.
when the tractor is cold the loader works fine, it raises fast and has plenty of lift power.
   / Case ih 385 loader won't lift #4
You might try a different hyd fluid.
   / Case ih 385 loader won't lift #5
Sounds like a tired pump !!!
You need to get the unit tested on a flow rather to test pump efficiency. Oil and filter can also affect performance so check theses first!!
2018 KENWORTH T270 SERVICE TRUCK (A51406)
2018 KENWORTH T270...
KUBOTA SVL97-2 SKID STEER (A52705)
KUBOTA SVL97-2...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
2002 VOLVO L150E WHEEL LOADER (A51246)
2002 VOLVO L150E...
2018 FORD F150 Ext Cab 4X4 Pick-up Truck (A55788)
2018 FORD F150 Ext...
2025 JMR 72in Dual Cylinder Grapple Skid Steer Attachment (A55787)
2025 JMR 72in Dual...
