Case ih 385 loader won't lift
   / Case ih 385 loader won't lift #1
bigred 01
wausau
case ih 385
I have a 1987 Case ih 385 with a 594 allied loader.
after the tractor warms up I lose my lift on the loader I still have down pressure, and I can dump the bucket.
The three point arms also works, the steering works but makes noise.
   / Case ih 385 loader won't lift #2
Install a gage and check the pressure.
Does you valve relief ever activate?
Can you raise the front wheels off the ground?
Is the spring centering on the valve working correctly. Sometimes the nut backs off the spring.
yes I can raise the front wheels off the ground with both the arms and the bucket.
the joystick for the loader just seems to go dead in the lift position after the tractor warms up.
the tractor started having the loader problem after I had run brushog on 3 point for 3 or 4 hours.
when the tractor is cold the loader works fine, it raises fast and has plenty of lift power.
   / Case ih 385 loader won't lift #4
You might try a different hyd fluid.
   / Case ih 385 loader won't lift #5
Sounds like a tired pump !!!
You need to get the unit tested on a flow rather to test pump efficiency. Oil and filter can also affect performance so check theses first!!
2022 JOHN DEERE 6120M LOT NUMBER 191 (A53084)
2022 JOHN DEERE...
YANMAR ViO45-5 EXCAVATOR (A51406)
YANMAR ViO45-5...
2014 Freightliner M2 106 24ft Box Truck (A52377)
2014 Freightliner...
48" WIDE WOODEN STAIRCASE W/ METAL RAILING (A54757)
48" WIDE WOODEN...
2021 Ford F-250 4x4 Ext. Cab RKI Service Truck (A52377)
2021 Ford F-250...
2018 Chevrolet Colorado 4x4 Ext. Cab Pickup Truck (A53422)
2018 Chevrolet...
