Case IH 245 cannot shift
/ Case IH 245 cannot shift #1
djuser
oxford,mi
case
(235/245 3cyl diesel Mitsubishi?) I was plowing snow and going back and forth from 2nd to Reverse often. Also pulling a blade in 3rd. (Range Medium). After about an hour, shifting down left for Reverse started "missing" and staying in N or 3rd. Then later got stuck in Reverse. Eventually it doesn't shift at all. I can move the handle up/down a bit with effort but not the normal "H" (1,2,3,R)action and doesn't shift into a gear like normal. When I release clutch the engine just slows/stalls. I'm able to roll the tractor with engine off with range lever in start/neutral, but makes a ticking noise while towing/rolling. That noise goes away with the clutch depressed. Hydraulics work. Any ideas? Thanks
I did check oil and was half quart low, hydraulic fluid full. Added oil and it does start and engine runs fine. Maybe shift linkage? transmission? Thanks!
/ Case IH 245 cannot shift #4
I don't know your tractor but it could be your shift linkage. The tractor may be in two gears at once. Something could have slipped or broken inside the transmission itself.
Massey Ferguson 383 Tractor (A64047)
Massey Ferguson...
24in excavator tooth bucket (A61307)
24in excavator...
Case IH 950 Planter (A63688)
Case IH 950...
1975 Bomag MPH1 Soil Reclaimer Mixer (A61572)
1975 Bomag MPH1...
2022 Case 5550 Trident Spreader LOW HOUR (A63688)
2022 Case 5550...
2005 Mack CL713 Truck (A60352)
2005 Mack CL713...
