Case DX35 hydrostat PTO problem.
/ Case DX35 hydrostat PTO problem. #1
Jeepnford
NE Missouri
Case DX35
I also posted this in the Case forum but tractor is dead in a bad place.
Tonight I was moving some firewood around with the tractor. Stopped, put it in idle, set the brake, lowered the loader and splitter, forgot to take it out of gear, jumped off and it died like it is supposed to. Jumped back on, put in neuteral, no start. PTO light is on, moved lever, same thing. Disconnected safety switch on lever, same thing. Shorted leads, same thing. I'm stumped. Any ideas? Thanks for any info you might have.
/ Case DX35 hydrostat PTO problem. #2
Check your gear shift lever.
/ Case DX35 hydrostat PTO problem. #3
If the PTO light is on, you have a shorted PTO switch. The problem is that this switch is normally open and when you engage the PTO, it goes closed. You should be able to disconnect the switch and it should start. If not, you have a short somewhere in the wiring that makes it think that the PTO is engaged.
I was gone most of the day today but disconnected the PTO switch and tried a different relay but still the same. Transmission is in neuteral. I need to try to get this thing pushed in the shop so I can take panels off and work on it with the wiring diagram.
/ Case DX35 hydrostat PTO problem. #5
Always a tough one.
I would check the sticky on the New Holland thread about the ignition switch issues. My DX33 fried two ignition switches that way honestly.
It was the number two fuse. I'll probably replace it with an auto reset breaker and do the relay upgrade later per the sticky.
/ Case DX35 hydrostat PTO problem. #7
Good to hear it was something simple!
New Electric Scooter (A65579)
New Electric...
New/Unused CFG Industrial NT18K Mini Excavator (A65583)
New/Unused CFG...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65583)
IMPORTANT PLEASE...
2021 Jayco Jay Flight 32BHS Camper (A62613)
2021 Jayco Jay...
1995 MACK RD690S T/A DUMP TRUCK (A64277)
1995 MACK RD690S...
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
