Case DX35 Hydraulic Squeal
   / Case DX35 Hydraulic Squeal #1
jletson
Case DX35
I have a 2008 Case DX35 that has developed a hydraulic squeal. It seem to be coming from the left side of the engine around the hydraulic filter but it is hard to isolate since it only does it when the tractor is in motion. I have replaced both filters and the issue has not improved. I can operate the front end loader without the squeal but it is slower than normal as well as the rear lift. The steering is also slow. If you have had this issue before let me know what the resolution was.
   / Case DX35 Hydraulic Squeal #2
Lower the 3 point hitch a bit from the full up position. If the squeal goes away the hitch follow up linkage needs adjustment.
I tried that and it didn't change anything. It pretty much only does it above 2000 RPM's while moving. No noise at all sitting still. Do you have any other suggestions?
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2009 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2009 Ford F-250...
2005 LUFKIN 48X102 SPREAD AXLE FLATBED (A50854)
2005 LUFKIN 48X102...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2015 Chevrolet...
