case/david brown 1594
/ case/david brown 1594 #1
paull
DAVID BROWN 1594
Hi every one can someone please help I need crankshaft for my 1594 urgent thanks
/ case/david brown 1594 #2
Did you try any of these outfits on google ?
Google
Boone
yes but no luck as yet
/ case/david brown 1594 #4
You may want to double check, but this should be the part number for your crank, K914788. Looked it up through Case/IH.
I also Googled the part number, and got several hits... 3 apparently used, ( no price shown) and one.., (cough.., cough..) new one through Messicks... $2900.00+
thanks DJ Iwill try again,as nothing comes up here in Australia
DJ can you send links to crankshafts found as I still get no results here with Google etc thanks paull
/ case/david brown 1594 #7
K914788 - Tractor-Part, Find Tractor Parts
Got three results, but one has an "R" suffix... Not sure what that is...
But please double check to make sure it is the correct one... Wenger's should be able to tell you if it is the correct one, and used in both tractors. They show it/them out of a 1690.
Hope the link works..!!
Thanks heaps DJ
UNUSED WOLVERINE SB-12-72W 72" HYD SCREENING BKT (A62131)
UNUSED WOLVERINE...
17109SFL (A61569)
17109SFL (A61569)
2013 John Deere 1770NT Planter (A63109)
2013 John Deere...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
Ingersoll Rand Air Compressor (A61166)
Ingersoll Rand Air...
2007 FREIGHTLINER M2 106 4X2 26FT BOX TRUCK (A59910)
2007 FREIGHTLINER...
