Backhoe Case backhoe, wain roy bkt slow
   / Case backhoe, wain roy bkt slow #1
spo307
Levittown & Long Eddy NY
kubota L4400
Hello, we have 2 case 590 super m + series 3 backhoes, machine 1 came with a wain roy 4 in 1 B/H bucket, gr8 power through out. machine 2 wain roy was added after. PROBLEM. machine 2 when I use the B/H bucket to grab something its slow to open close to close and not much force ( rpm's all the way up) is there a way to increase flow to B/H bucket for greater force and speed. machine 1 has a flow dial above the gas tank for flow. is machine 2 internal, can it be adjusted in the feild ( by operator ) thanks for your help. Dennis
   / Case backhoe, wain roy bkt slow #2
Are we to assume that with backhoe two that the only function that is slow is the bucket jaw cylinder? At full engine rpms' everything should be fast.
   / Case backhoe, wain roy bkt slow #4
Sounds like a worn out pump or if noisy maybe a stopped up filter(s). Have you tested pressure with a guage to know what your system can do? For the record I have never had to run a Case 580 or similar at rated speed to dig with it.
If you retract a cylinder complete and hold it for a second can you hear the relief valve kick in? If not that is a good sign your system is not up to max pressure and delivery.
Steve
2021 PETERBILT 389 MID-ROOF SLEEPER (A52472)
2021 PETERBILT 389...
2013 INTERNATIONAL SA615 ROUSTABOUT (INOPERABLE) (A52472)
2013 INTERNATIONAL...
New Bulk Lot Chain Slings (A53002)
New Bulk Lot Chain...
Deutz 2WD 53HP Utility Tractor (A51691)
Deutz 2WD 53HP...
2008 MAGNUM TRAILER LIGHT TOWER TRAILER (A52472)
2008 MAGNUM...
10x16.5 Tire Assembly (A52748)
10x16.5 Tire...
