Backhoe Case backhoe, wain roy bkt slow
   / Case backhoe, wain roy bkt slow #1
spo307
Levittown & Long Eddy NY
kubota L4400
Hello, we have 2 case 590 super m + series 3 backhoes, machine 1 came with a wain roy 4 in 1 B/H bucket, gr8 power through out. machine 2 wain roy was added after. PROBLEM. machine 2 when I use the B/H bucket to grab something its slow to open close to close and not much force ( rpm's all the way up) is there a way to increase flow to B/H bucket for greater force and speed. machine 1 has a flow dial above the gas tank for flow. is machine 2 internal, can it be adjusted in the feild ( by operator ) thanks for your help. Dennis
   / Case backhoe, wain roy bkt slow #2
Are we to assume that with backhoe two that the only function that is slow is the bucket jaw cylinder? At full engine rpms' everything should be fast.
   / Case backhoe, wain roy bkt slow #4
Sounds like a worn out pump or if noisy maybe a stopped up filter(s). Have you tested pressure with a guage to know what your system can do? For the record I have never had to run a Case 580 or similar at rated speed to dig with it.
If you retract a cylinder complete and hold it for a second can you hear the relief valve kick in? If not that is a good sign your system is not up to max pressure and delivery.
Steve
PALLET LOT OF WINDOWS & WINDOW SILLS (A58374)
PALLET LOT OF...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
New/Unused Electric Golf Cart (A57453)
New/Unused...
NEW Thiessen Track Closer Disk (A56435)
NEW Thiessen Track...
1459 (A57192)
1459 (A57192)
2004 TRAVIS BODY & TRAILER DOUBLE ALUMINUM BELLY DUMP COMBO TRAILER (A58214)
2004 TRAVIS BODY &...
