Case 970 adding loader
/ Case 970 adding loader #1
farm boy00
Howard City, MI
John Deere M&MT, Case 1030 comfort king, Sears ST16, Craftsmen 6000, homemade articulation mini-loader
Looking for opinions on adding loader and backhoe hydraulics
Case 970 power shift.
Installing a loader and a 3pt backhoe.
Planning on tapping into the pressure line after the pto valve before the 3pt/outlets.
Feed pressure into the loader valve then power beyond back to a quick connect for the backhoe with a power beyond back to the 3pt.
But haven't torn into it fully. Have not seen a great location to run a drain back to the rear end.
Mainly will be used as an oversized loader tractor 75% of the time. Backhoe is just an occasional use so I dont have to rent one when needed. Not worried about it being a 3pt because it won't be used maybe 3-5 times a year after a few projects this spring
/ Case 970 adding loader #2
I did that very power beyond mod to a 1070 years ago for a loader. There wasn't a
good place for the return on that tractor either. I drilled and tapped a hole in the PTO housing. I tried the fill port first but that part of the housing couldn't take the
return flow fast enough. I don't recall how similar a 970 and 1070 are in the rear end. I did consider using a drain port but was worried it could get knocked off and that would end badly.
2019 FREIGHTLINER 122SD 6X4 T/A TRUCK TRACTOR (A67148)
2019 FREIGHTLINER...
2023 Bobcat T595 Compact Track Loader Skid Steer (A64553)
2023 Bobcat T595...
John Deere 12in Channel Bucket w/ Teeth Excavator Attachment (A64194)
John Deere 12in...
2022 EZ-GO ELITE...
20 Ton Air/Manual Hydraulic Bottle Jack (A64557)
20 Ton Air/Manual...
2025 IRanch IRTPL 10,000lbs. Two Post Automotive Lift (A64194)
2025 IRanch IRTPL...
