Case 730 restoration
/ Case 730 restoration #1
deereman75
canada
Deere 2120, Warner & Swasey 6000# offroad forklift, Case W9B loader, various non-running decorations
Well here it is, I have finally got the before pictures. Stay tuned for updates.
/ Case 730 restoration #2
Looks great. I was waiting for the pics on the other thread. Have fun. It looks to be all there and in operational condition.
Ran into a bit of an issue yesterday. The only grinder I could find had the plug melted off. Today I will go into town, get a new grinder and see how well those rapid strip discs work
/ Case 730 restoration #5
Pretty cool to see a Wheatland/Standard tread model, let alone a factory cab. All around this area that I've seen were row crop versions.
Keep us posted..!!
Up here in Alberta, narrow front tractors are as rare as hens teeth. I think the cab will be very nice, even more so if it had a heater.
/ Case 730 restoration #7
Any updates? How well did them rapid strip discs work?
Well there hasn't been much visual progress. All that is different is a little less rust, a lot less grease, and the cab fan smashed up on the ground. (figured that since the fan was rusted solid and missing parts it could go) as for the rapid strip discs, the knockoff of the Norton I got (think it was called Avanti pro or something like that) is only good at removing paint, not so much at rust, also it lasts for about 5 minutes, and costs like 2x what a wire wheel does. After I half wore it out on one small panel, I tossed it in the back of the barn, and grabbed a wire wheel.
/ Case 730 restoration #9
Good to hear your making progress. I like using an orbital sander on body panels and a sandblaster and wire wheel on casting.
/ Case 730 restoration #10
I have had the best results with a 4" twisted wire cup brush... Depending on the surface, a straight wire cup brush works well to get into crevises.
For small items, I have experimented with electrolosis rust removal. Works great, and easy final clean up with a cup brush.
/ Case 730 restoration #11
Saw a 930 Case Wheatland, no cab, in the local Craigslist last night for $2900. Says it runs well. Over 7,000 hrs. on it...
/ Case 730 restoration #12
Nice looking project you have there
/ Case 730 restoration #13
Deereman75, you must be busy working on the tractor and forgot to give us some updates and photos.
I will get some up today, after the water dries up. I actually had to get a new pressure washer, as the old one was shot. Some of that grease just won't go... After at least 3 scrubbing with tsp, it a very, very strong mix, and at least 5 power washings with an industrial degreaser, followed by a rinse with the turbo nozzle, there is still some little bits left. I just finished the final washing, so once the tractor dries, I will go and get that gallon of varsol from the barn... Seeing as I don't have my sand blaster here, I just sanded and brushed all the loose rust and paint off. I have a few rattle cans of rust primer to put on any bare metal or rust I can't remove. My plan is to have the priming done today, and do the final prep (masking ect) in the morning, and get the first coat on the body done tomorrow. If it seems like a while between updates, it is likely something like the storms that seem to happen every second day here preventing me from getting anything done. I will be sure to update twice and today, once after final cleaning, and once after priming. (assuming I have enough primer) stay tuned, I will hopefully update in a few hours
Okay, here it is. First of all even varsol wouldn't remove that gunk, I am sure it has to be a stain on the casting, as nothing will get it off. So I got the outside of the cab primed, then I ran out of primer. I will have to go into town tomorrow, and get a few more cans.IMG_00000024.jpg
/ Case 730 restoration #16
deereman75 said:
Okay, here it is. First of all even varsol wouldn't remove that gunk, I am sure it has to be a stain on the casting, as nothing will get it off. So I got the outside of the cab primed, then I ran out of primer. I will have to go into town tomorrow, and get a few more cans.<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=277012"/>
Did you try some of that Gunk Engine Bright or Simple Grean or Formula 88 for the gunk removal. I have had great succsess with all them.
Simple green is what I was using with the power washer, it was amazing on everything else. I will have to see if I can find a can of gunk or carb cleaner, they are the only things I find work better then varsol.
/ Case 730 restoration #18
Another way to remove the bulk of the crap fast is to use a puddy scrapper then use the washer and solvent.
Well another long overdue update, I am going to finish tomorrow at the latest. I just have the finish coat on the body left. I have been taking pictures, I will upload them all at once.
/ Case 730 restoration #20
Finally. Do you have all the decals for it or did you mask of the ones that were on there.
Deer Target (A64912)
MQ Power MQP80IV Industrial Generator (A64912)
MQ Power MQP80IV...
2016 FORD EXPLORER SUV (A67737)
2016 FORD EXPLORER...
PALLET OF 2 SHOP VACS AND SHOP BROOMS (A67714)
PALLET OF 2 SHOP...
2017 Ford F-450 XL (A64911)
2017 Ford F-450 XL...
Detroit Diesel 3 Cylinder Power Unit (A64912)
Detroit Diesel 3...
