case 630 caseomatic lifting capacity
/ case 630 caseomatic lifting capacity #1
richwolfe
Pine Grove PA
case 630 caseomatic
Hi, i just had the loader on my case 630 worked on and it still does not lift anything "heavy". My issue is i need it to lift about 1500 lbs and so far the heaviest thing i picked up about 3" is a 55 gallon barrel of concrete. i was told this tractor should easily lift this much weight, is this correct? The place that worked on it said it has about 1400 lbs of preasure with a replaced hydraulic pump. Any ideas?
/ case 630 caseomatic lifting capacity #2
1400 psi of pressure does not mean much as you have to know the cyl bore size , and the angle the cyl is to the lift arm, and any other mechanical advantage.
You can do a test with 55 gal drums of water as each will weigh about 470 lbs.
Somewhere I read the weight of a 55 drum of concrete, and it was about 900 lbs.
Forks and Frame Mini Skid Steer Attachment (A61572)
Forks and Frame...
Fendt FT900 Front Fenders (A63117)
Fendt FT900 Front...
2024 Schulte 5026 Batwing Rotary Cutter (A63688)
2024 Schulte 5026...
2005 Butler pole trailer (A62679)
2005 Butler pole...
1080 (A64280)
1080 (A64280)
UNUSED X-STAR GRAVEL LEVELER (A64280)
UNUSED X-STAR...
