case 580d tachometer question
/ case 580d tachometer question #1
chrisdvorak
RI
too many
I am trying to get the tach working on my 81 case 580d. I had the dash apart today and found that the gauge itself is working but there is no cable attached to the back of it, I'm not sure if the previous owner removed the entire cable or what but I cant seem to find it. does anyone know where the tach cable attaches to the engine? and also if the cable is inside the wiring harness or separate?
-thanks chris
/ case 580d tachometer question #2
The tach cable runs from the back of the tach down to the right side of the engine block behind the alternator, if its like my 580C. Tach drive is very expensve to replace
thanks, I will check behind the alternator and hopefully I can find it, is the drive you are talking about number 1 in this diagram?
Parts for Case 580D Loader Backhoes
I managed to get a pic of the right side, should the drive be coming out of what looks like a little tube coming out of the block? IMG_0145.jpg
/ case 580d tachometer question #5
You found it - just in case, here's your pic back with confirmation. That little knurled ring at the lower end of the indicated part is the drive gear - hopefully it's in good shape 'cause it's twice what they want for the cable.
HTH... Steve
Thanks for the help! Does the cable go inside the harness or is it separate going up to the dash?
/ case 580d tachometer question #7
The cable runs by itself up to the dash. Unscrew the knurled knob on the crankcase fitting, and see if you can see or feel anything turning when the engine is running. If not, you will have to replace the drive assy and the entire cable assy. The drive assy is difficult to remove from the block. but it will come out. Expect to spend about $150 to replace the pair. The hobbs meter has a 100ths wheel that is covered, so if you get it repaired, the first time it turns over all the digits, and looks like the hobbs is no longer working, relax, after 1/10 of an hour you'll see it move. A mini tach is probably a more economical fix.
2007 Ford F-150 Pickup Truck (A64194)
2007 Ford F-150...
HD Bale Ring (A66408)
2021 Kubota SVL 97-2 (A62177)
2021 Kubota SVL...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
STIHL HT131 POLE SAW (A62613)
STIHL HT131 POLE...
2022 CATERPILLAR 289D3 SKID STEER (A64279)
2022 CATERPILLAR...
