Tractor Sizing CASE 580C weight
/ CASE 580C weight #1
KB9UDE
Platinum Member
North of Tower Hill, IL
John Deere 4066r John Deere 2025r
Hi guys...
Any Ideas what this 1970's Case 580c might weigh??
Thanks
John
/ CASE 580C weight #3
I just looked through the 580K operators manual and service manual and neither has listed a weight for the machine!
But it does say that the 82" fel bucket is 760 pounds and the 24" bh bucket is 270 pounds. Other buckets are different.
I'd go outside and check the nameplate but it's pouring right now. I'll check it later and make another post here.
I'm back. My nameplate says that my 580K machine has a max weight of 7938kg. That's 17,500 pounds! Now what does max weight mean and does it include the buckets weight?
You aren't the first to ask this question. Here's another thread on the same subject.
http://www.tractorbynet.com/forums/construction-equipment/37324-case-580c-specs-mid-seventies.html
/ CASE 580C weight #5
Ballpark for a 580C is 15,000 lbs. If you need to be more specific it is much more accurate to simply weigh the machine....depends on extra features, combination of buckets etc.
/ CASE 580C weight
OK thanks Steve...
I thought it might be in that range. Next time I have one around an elevator I will check for sure.
John
/ CASE 580C weight #7
/ CASE 580C weight #9
I used to use my neighbors 580C for grading my drive. we had a place to buy gravel just down the road and I always showed 12,500# empty on the scale. I used to run down and grab a bucket of gravel at a time for filling pot holes.
/ CASE 580C weight #10
That is dead on what the JD 310 of that era weights I know and when looking they seemed about equal just from looking at the two brands.
/ CASE 580C weight #11
I am going with 12.5K. I had an 88 580K 4X4 Extendahoe with full glass that scaled at 14K.
/ CASE 580C weight #12
I agree. My brother has a 580 an its about 12,000# and my neighbor has a much new 580 with cab and glass and he says its 14,000#.
Only way to know for sure is to weigh it.
Chris
2018 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A65057)
2018 CHEVROLET...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A66738)
2021 Mercedes-Benz...
Case 75 (A64911)
Case 75 (A64911)
20t Ton Air/Manual Hydraulic Bottle Jack (A64557)
20t Ton Air/Manual...
330 GAL WATER TANK (A68842)
330 GAL WATER TANK...
2020 FORD F-150 XL CREW CAB TRUCK (A65054)
2020 FORD F-150 XL...
