Case 560 Swing Arm pins
/ Case 560 Swing Arm pins #1
graemeian
I have a Case 560 Super K in great shape. One of the swing arm cylinders has a leak and I will order the kit tomorrow. Since I have the pin removed, I was considering making over-sized pins to reduce play in the hoe boom. What would be the minimum bushing to pin clearance for the ~1.6" pin? I will measure the minimum diameter from the three hardened bushings and use measurement as reference. I ordered a repair manual for the Case in pdf form and I cannot find the clearance written in the manual. I will make the pins from mild steel. Thank you.
2016 FONTAINE VELOCITY FLATBED SEMI TRAILER (A61568)
2016 FONTAINE...
2012 John Deere 1990 Planter (A63109)
2012 John Deere...
Great Dane Van Trailer (A63118)
Great Dane Van...
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
SET OF METAL RAMPS (A63745)
SET OF METAL RAMPS...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
