Case 530 and electrical.
/ Case 530 and electrical. #1
beeze455
Bowdoinham, ME
Case 530CK
Done a lot to this beast and now it is time for the electrical. It currently only has an alternator with no wires. I would like to have the alernator charge the battery and run some lights. Do I need a voltage regualtor between the alternator and battery? Can I just run lights right from the battery or should I do it from the alternator?
/ Case 530 and electrical. #2
Since you have an alternator I assume it is not original. You will need to check the alternator to know if and which voltage regulator to get. Better deal and near the same money is go buy a rebuilt single wire delco alternator. You connect one wire from the alternator to the battery and you are done. Should be less than $50 for a 35 amp alternator.
Yea, I think it is actually charger. I am going to convert it to an alternator. I am liking this single wire delco alternator idea. Should only need to make a bracket unless somebody knows of one that fits.
Rotary Brush Cutter Tractor Attachment (A61572)
Rotary Brush...
2024 8R 370 Tractor (A63111)
2024 8R 370...
2018 F550 Bucket Truck (A63689)
2018 F550 Bucket...
2006 Montone AD24465448 30ft. Tri-Axle End Dump Trailer (A61573)
2006 Montone...
NO ADDITIONAL ONLINE BUYERS PREMIUM ON BID.FIVESTARAUCTION.COM (A64047)
NO ADDITIONAL...
2006 MINI Cooper Convertible Coupe (A61574)
2006 MINI Cooper...
