Case 480D backhoe Alternator Belt Replacement
/ Case 480D backhoe Alternator Belt Replacement #1
bill Treff
Case 480D
Does anyone know whether or not you have to remove the from hydraulic pump to replace the alternator belt on a Case 480D backhoe loader. The hydraulic pump is attached to the front of the crankshaft after the lower pulley. It appear that the pump has to be removed to replace the alternator belt. Is there an alternative? Thanks, Bill Treff
/ Case 480D backhoe Alternator Belt Replacement #2
G'day most of the ones i have worked on you only have to undo the drive on the lower pulley and you should be able to push it back towards the pump and you can wriggle the belt through you may have to turn the coupling through 90o to get it through.
Jon
/ Case 480D backhoe Alternator Belt Replacement #3
Yes there is
/ Case 480D backhoe Alternator Belt Replacement #5
When the belt broke on my 480 I replaced the belt with one of those link belts. It was a little pricey but has held up great and I didn't need to remove the hydraulic pump.
2021 John Deere S790 S Combine (A63111)
2021 John Deere...
CADMAN 4500 WIDE BODY HARD HOSE TRAVELER (A63291)
CADMAN 4500 WIDE...
2007 International 7500 sba Flatbed 6x6 Truck (A62679)
2007 International...
2014 KUBOTA SVL75-2 SKID STEER (A64279)
2014 KUBOTA...
207923 (A63290)
207923 (A63290)
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
