Case 446 snowblade mounting bracket
   / Case 446 snowblade mounting bracket #1
CaseRedneck
I'm looking for the brackets to mount my factory snow blade to my 446. I just put a Briggs Vangaurd motor on this old tractor and it works great the only problem is that some idiot (me) cut up the old mounting bracket a couple of years ago and mounted it to his 4wheeler but now I want to put it back on the tractor since that project is done. Any help would be greatly appreciated.
   / Case 446 snowblade mounting bracket #2
There are at least a couple of Case / Ingersoll tractor forums on the web. I'd suggest that you google to find them, then post there. Surely they will have sources for new and used parts.
   / Case 446 snowblade mounting bracket #3
Aren't those Case garden tractor the greatest! Mine is 30 years old and still running great. Of course it's had a lot of TLC. There is a casegardentractors.com web site. Even though I have a BX2660 with a FEL and a rear blade, my Case is still the best snow pusher (with chains and rear 100 lb weight)....except for piling up large amounts of drifted snow. Good Luck.
2015 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2015 Ford F-250...
(INOP) NEW HOLLAND B95 BACKHOE (A50459)
(INOP) NEW HOLLAND...
1989 Freightliner Cabover FLA086 (A52128)
1989 Freightliner...
HUSKY 135 PSI AIR COMPRESSOR (A50854)
HUSKY 135 PSI AIR...
(2) 300 GAL WATER TANKS (A50854)
(2) 300 GAL WATER...
HUNTER SYSTEM 700 TIRE BALANCER (A50854)
HUNTER SYSTEM 700...
