Case 442
/ Case 442 #1
Redfisher
Fergus, Ontario,Canada
Cub Cadets 104,129,149, Jinma 284
I'm having a hard time finding any info on a Case 442,I'm looking for a picture and the year for this s/n 9633633
Any help would be cool.
/ Case 442 #2
I know 0 about Case /w3tcompact/icons/frown.gif but I did check my reference books and couldn't locate 422 also the serial number.
Would the Case 422 be a lawn and garden Tractor or a field tractor.
/ Case 442
Hi Thomas, The 442 is a lawn tractor and i think it is a ingersoll case? I could be wrong but when I do search's for this lawn tractor I keep getting Ingersoll.My Dad bought one but has not brought it home yet,so i was looking for info on them.He said the rear tires are almost as high as your hip./w3tcompact/icons/smile.gif
/ Case 442 #4
I'm pretty sure that's all you'll come up with for your 442. It's ingersoll with a case label now. Have worked on a few. Not a bad machine at all.
/ Case 442 #5
OK, here we go. This tractor is a Case garden tractor. In the early 80’s Ingersoll bought the garden tractor part of case. For the first 5 or so years the tractors had Case, and Ingersoll on them. Your tractor is a lot older then that. I just picked up a Case 446 it’s an 81 and it is just a case,but my 84 224 has Ingersoll, and Case on it. The way the Case tractors were named tells you about the tractor. The 44 means it is a big wheel[16” rear wheel] high ground cleance tractor. The last # is the HP of the motor. Your 442 would be a 12hp. There was also a 444 [14hp] 446 [16hp], and 448[18hp] I believe the 442’s were only made in the early 70’s. There is also a 22_ series tractor. These had small rear wheels [12”] They had a 220[10hp], 222[12hp], 224[14hp], and a 226[16hp]. I do not think they had an 18hp small wheel tractor.
Now that you know about the model brake down, I will tell you a bit about the tractor.
They are hydraulic drive. The motor drives a hydro pump, which runs a hydro motor on the two speed transaxle. Most of these tractors had hydroic lift also. You could also attach a hydraulic PTO on the back to run hydraulic attachments.[log splitter, leaf vac, tiller,etc] These are real tough tractors. Built like tanks. How do I know? I have three. A 224 with a log splitter, a 444 with a vac, tiller, and a plow blade, and I just got a 446 also with a plow blade.
/ Case 442 #7
No problem. If you have any other ?? feel free to ask.
BTW the two tractors in the picture are a 444 and a 224. Your 442 will lok a bit like the 444. The color will be different though.
/ Case 442
Hey s1120 heres a pic of the beast (442) /w3tcompact/icons/smile.gif
Strong little tractor.
/ Case 442 #9
Looks nice. I have done a bit more digging for you, and it seems that the 442's were only made 2 or 3 years. 70-72 I think. So you got an old girl there. Take care of her.
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
2011 Kenworth T300 S/A 18ft. Cab and Chassis Truck (A64194)
2011 Kenworth T300...
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A64194)
2010 International...
2022 Chevrolet Silverado 6500HD 4x4 Service Truck (A64194)
2022 Chevrolet...
2008 MACK CHU613 DUMP TRUCK (A63569)
2008 MACK CHU613...
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
