Case 380CK Loader Hydraulics
/ Case 380CK Loader Hydraulics #21
The loader and the three point system are run from two different sources. The three point on a 380 runs on the transmission oil system while the loader gets its pressure from the pump at the tractors front of the tractor. If your hydraulic oil is good and the filter is not plugged, I would have someone check the hydraulic pressure on the pump. You might also want to check the seals, etc. in the cylinders. Bill
In general, I'm fairly new to tractors - and I'm even newer to this Case 380CK Loader/Landscaper, so any feedback at all would be appreciated...
Since I picked this tractor up, for the loader to function at all (even with just an empty bucket), it needs to be running at about 1000+ RPM. To lift the front end of the tractor, or handle a bucket with some dirt in it with any sort of reasonable speed, 1800+ RPM. Even at full RPM, it seems weak, although it has done everything I've asked it to so far.
I haven't notice any leaks, etc.
It doesn't seem like this would be normal. Any advice that you can give me on troubleshooting, would be appreciated. Could this be anything other than a pump?
Thanks
2018 MACK LR633 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR633...
2015 Ford F-250 Knapheide Service Truck (A66736)
2015 Ford F-250...
Unused 2023 Paladin Auxiliary Hydraulic Oil Cooler Skid Steer Attachment (A66734)
Unused 2023...
TIRE REPAIR WORK BENCH (A68842)
TIRE REPAIR WORK...
2011 CHANDLER TRI AXLE SPD-18 WATER HEATING TRAILER (A67714)
2011 CHANDLER TRI...
2014 MAC FLAMELESS HEATER TRAILER (INOPERABLE) (A67714)
2014 MAC FLAMELESS...
