Case 360 fuel tank full of rust
   / Case 360 fuel tank full of rust #1
LDR812
Central Florida
New Holland TC33D, MF 165
Hi - I’ve got an old case 260 trencher/ hoe with a Wisconsin gas engine. The fuel tank is really thick metal but also very rusty inside. When I was a kid we would take something like that to a radiator shop and have it boiled out and sealed. I’m in central and north florida Ocala / Gainesville / Jacksonville and can’t seem to locate a old time radiator shop. Anyone local to this region point me too a shop that still tanks this type of thing? Thank you
   / Case 360 fuel tank full of rust #2
I've DIY'ed a few tanks like that. Take the tank off and dump out as much rust as you can, stick a few short pieces of chain and/or a few good heaping handfuls of nails and roll it around. I have ratchet strapped them to an electric cement mixer, a pipe threading machine, really anything that you can strap the tank to and let it roll around for a while. Once that's done dump everything out and it should be pretty clean, if it's not up to snuff then some muriatic acid followed IMMEDIATELY by neutralizing and add either your coating of choice or just filling it with fuel. At this stage the inside of the tank will be very susceptible to flash rusting.
   / Case 360 fuel tank full of rust #3
^^Done that before. (y) We tied the tank to the wheel of the tractor that still had it's chains on the tires. The chains offered a great way to securely tie the tank to the wheel.
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
JOHM DEERE 1600 WAM LOT NUMBER 125 (A53084)
JOHM DEERE 1600...
2018 TAKEUCHI TB290 EXCAVATOR (A51246)
2018 TAKEUCHI...
City of Buckhannon - 2014 Ford Fusion SE (A52384)
City of Buckhannon...
2022 Adams CLC-1013 Conveyor - New (A53472)
2022 Adams...
1/2 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/2 '' Wolverine...
