case 220 hydriv
/ case 220 hydriv #1
cbee
case
when mowing the yard and start up a steep incline it will not pull itself and rider up the hill. can anone tell me what the problem is? The motor is in perfect shape and runs fine. It is at full throtle and still won't go up hill.
/ case 220 hydriv #2
When was the last time that you drained the oil in the hydraulic reservoir?
Tell me the brand of oil and the weight of the oil that you put back in.
/ case 220 hydriv
i just got this mower 3 days ago free. it had been setting for 7 or more yrs and never been used and i put a battery in it and it fired right up and mowed the grass of course after i adjusted the clutch on the pto. So i guess i will drain the hydrolic oil and put some 20w 40 in it for summer running and try it agian.
/ case 220 hydriv #4
You will have a hard time finding 20W40. Use 20W50 instead. Much easier to locate. There is a 1/4" pipe plug with an allen head that screws into the bottom of the travel/lift valve under the checker plate floor. Clean out the hex hole thoroughly and use a socket wrench allen wrench that is pushed into the hole all the way to remove the pipe plug. You get one chance to remove this plug. If you round out the hex, you have to weld a wrench to the plug. That is the drain hole. Remove the plug, start the engine at idle and pump out the old oil until you see air spurting. Shut the engine off immediately, replace the plug and refill the reservoir. Purchase 7 quarts of oil to be on the safe side. For sure, you will use five to six of them.
Then test the tractor once again and let me know what happened. Often it is just the wrong oil in these tractors but... it may be a badly worn pump.
PALELT OF BED KNOCKERS & MISC PARTS (A64278)
PALELT OF BED...
2018 CATERPILLAR 320 EXCAVATOR (A65053)
2018 CATERPILLAR...
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
2020 Toro Groundsmaster 7200 72in. Zero Turn Commercial Mower (A64553)
2020 Toro...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
2017 Forest River Rockwood HW275 S/A Pop Up Camper Trailer (A64557)
2017 Forest River...
