Case 1070 Hydraulic Issue
/ Case 1070 Hydraulic Issue #1
Roughboy79
Fort Cobb,OK
Case 1070
I recently picked up a 1975 Case 1070 100hp. It has to Hydraulic levers therefore I have four Hydraulic connectors on the rear. I have found that when I hook up to anything I have to use both levers in opposite directions of each other to raise or lower any implements. Anyone have an idea as to why? What I mean is when I hook up to my disc to raise it I have to push the lever to the in position while pushing the other lever that I am not connected to in the out position. Has the remote valve possibly been assembled incorrectly? I don't know if it has ever been opened or not, I just assume some o-rings and gaskets would have been changed by now.
/ Case 1070 Hydraulic Issue #2
my guess your hooking hoses up wrong try moving one hose to another port move only one and may have to move it again to find the right pair
New/Unused Mini Quick Attach Auger with Bit (A65583)
New/Unused Mini...
Quick Attach Backing Plate (A65579)
Quick Attach...
New/Unused Landhonor Gantry Crane (A65583)
New/Unused...
New Quick Attach Power Spreader (A65579)
New Quick Attach...
2006 INTERNAITONAL 7600 6X4 T/A DUMP TRUCK (A66091)
2006 INTERNAITONAL...
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
