Ballast Cart Solution
/ Cart Solution #1
funwithahoe
Anyone make/buy an easy way to store and remove/move your ballast box? My box has been sitting tipped over in my driveway because it is a pain to put on and really not too stable when not on the tractor. I want to build something where I could put it on in a minute and a 6 or 7 year old couldn't tip it over on themselves (or my foot).
Thanks! I always appreciate the great info on here and have used some of the great idea. - Oh and I already searched the 'Bota threads for an answer.
/ Cart Solution #2
I just bought 4 caster wheels that I plan to mount onto some type of 2x4 or 2x6 frame to keep the ballast box on. In my situation it'll be stored on a concrete surface so the wheels will allow me to move it a little when mounting it.
/ Cart Solution #3
Because of storage space and my insistence of storing my tractor and implements inside required me to build some carts for my 6' cutter and 8' grading scraper.
I thought long and hard about the best way to contrstruct. Because of clearance issues (I wanted to store my implements under an existing workbench), I chose to screw two sheets of 3/4" plywood together. This was done instead of building a frame to mount the wheels. I then bought four caster wheels at home depot and bolted them to the fours corners of the plywood. Plywood and casters is it -- no framework at all.
I built one for my 900# grading scraper and one for my 1100# rotary cutter. They roll around very easily in my garage and have been quite handy.
Now that I think about it, I actually built two small ones for my cutter. This way I am using 8 casters instead of four. I did this because my cutter was heavier than the rating of four casters. The scraper is using just one.
They also make hitching up a snap!
I will build two more soon: one for my pallet forks and one for my ballast box.
/ Cart Solution #4
Yeah, most people seem to make a dolly with store bought castors and a frame and plywood or something. You will need to have it on a smooth level surface like concrete or asphalt, because if it's 500 pounds or more it won't roll on gravel or grass with 3 inch or smaller castors (obviously).
/ Cart Solution #5
Almost all of my implements are on casters (castor is a plant whose beans produce a type of oil that you swallow to loosen up your insides :eek:). They (the implements on dollies) roll up to the 3ph and align with the touch of a pinkie.
/ Cart Solution #6
Is there any reason not to bolt heavy duty casters to bottom of ballast box?
/ Cart Solution #7
That's what I have and I love it for its simplicity.
When I need to I can place tractor weights or cinder blocks on that simple slide on/off holder.
Here I cobbled some cloths line to the roll-over bar to assist and make possible the cartage of long handled tools.
Now when I multi-task on the trails my bucket is always free. My creaky old knees appreciate the way less requirements to mount/dismount when I was using the bucket as a hasty tool carrier.
You don't really need a whole lot of weight, less weight properly positioned will do what you want it too.
Steel Blasting Shed (A62679)
Steel Blasting...
2011 Black Troxell T120 Vacuum/Water Hauler (A64194)
2011 Black Troxell...
10in. Auger Bit (A65640)
10in. Auger Bit...
2010 John Deere 1720 (A64126)
2010 John Deere...
Massey Ferguson Hesston 1745 (A64126)
Massey Ferguson...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
