Carrying spare stuff on the tractor?
   / Carrying spare stuff on the tractor? #12
My plastic ammo box leaks. I tried to make an improved gasket with hot glue, no luck.
This is what I came up with:
This is what it looks like off the tractor.
Here is the bottom.
Here it is hung.
The caddy is made of a SMV bracket, a 4 inch shelf bracket, a 3 inch PVC coupler, a 4 in PVC end cap and coupler a cut up can koozie, some bolts and zip strips.
What do you all think?
   / Carrying spare stuff on the tractor? #15
I have no luck carrying carbonated beverages on my tractor or mower. The vibration quickly flattens it out
The beer does too. :( But at least I don't have to really worry about it spilling. And it allows me to light up while still having something to drink afterward.
   / Carrying spare stuff on the tractor? #17
Just an update.
I drilled a two holes through the bottom of the big side to let out any water it collects (the occasional rain that makes it under the tractor's shelter). I need to make sure that the grease rag is all the way in. When I brush by a tree or bush it can pull it out. But otherwise it is working well.
   / Carrying spare stuff on the tractor? #19
Pretty innovative. (sp?) I don't want to start drilling into the tractor. I like the idea of using what is available.
Thanks.
I didn't drill anything in the tractor. The holes were drilled in the end cap piece. That is the larger of the two cylinders. I was finding dew and other liquid collecting in it.
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A52384)
2011 Autocar ACX64...
Woods LR72 72" 3pt Rake (A50774)
Woods LR72 72" 3pt...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
2007 Eager Beaver 35 GLB Lowboy, Tandem Axel (A52384)
2007 Eager Beaver...
