Carryall for your carryall ...
   / Carryall for your carryall ... #1
wrooster
Platinum Member
After the 87th time needing some random tool/item while out and about on the tractor, I decided to build a carryall for my carryall. My goal was also to make it detachable so that if I didn't need it, it could be left. I finally settled on the approach shown below.
Note that an interesting side effect of this approach is that the carryall box can in fact be attached either towards the back or the front. However, on smaller tractors such as my BX, be aware that depending on how deep you make the box it may hit the ROPS (etc) when the TPH is at it's highest position.
The attached pictures should tell the rest of the story.
n.b.
Note that the carryall box can be stored practically any place there is a horizontal 2x4. I would have put up a piece of scrap on the shed wall and taken a picture for you folks, but the dinner bell rang and I simply looped it over a saw horse and said goodnight.
Regards,
Wrooster
ps:
my original carryall writeup is here:
http://www.tractorbynet.com/forums/attachments/200169-carry-all-project-number-872-a.html
continued...
   / Carryall for your carryall ... #3
Yes! We got the Picture!! :laughing: Nice little addition to your carry all! :thumbsup: Good wright up all so and Thanks for sharing! :cool:
   / Carryall for your carryall ... #5
Nice work!
It's great to have a place for small tools and other junk that is separate from the main load floor. Good place for your chain saw when you're carrying brush/logs below.
   / Carryall for your carryall ... #6
Nice. You just gave me an idea for putting a temporary tool box on my tractor. "Hook it on on the frame." (the tractor is a '53 with no sheet metal)
I like the photo documenting....as they say" a picture is worth a thousand words. You have got quite a few thousand there.:thumbsup:
   / Carryall for your carryall ... #7
great idea and nice workmanship, might use it for flower box as well:):D
   / Carryall for your carryall ... #8
I really like the easy on - easy off concept. Good idea :thumbsup:
   / Carryall for your carryall ... #9
I agree with with everyone else, Great idea, but heavier than it needs to be, could of made it out of 1X boards or 3/4 plywood. make it a little lighter, easier to put on and off if loaded with tools. Still a great attachment to an attachment :)
JB
I agree with with everyone else, Great idea, but heavier than it needs to be, could of made it out of 1X boards or 3/4 plywood. make it a little lighter, easier to put on and off if loaded with tools. Still a great attachment to an attachment :) JB
With the cantilever approach I took the box has to be quite robust, otherwise the first bump with a set of tools in the box will result in structural failure. If you use 1x6 pine for the side panels I think you will have to change the design. Do you have an approach in mind using 1x pine, or 3/4" plywood?
The way I joined the side panels to the front and back pieces was a tradeoff. In general, with such a short length of wood (especially hem-fir) you would never put big lag bolts into the end grain at both ends -- doing so is a recipe for splitting the wood lengthwise. But for this application it is the strongest way to do it, as you are pulling on the end grain; this is in contrast to lagging the side panels to the ends of the front and back pieces, where the weight in the box wants to "twist" the side panels. (And this is primary the reason why 1x6 pine will not work in a cantilevered design -- that twisting under load will quickly crack the pine).
Nevertheless, I confess to *really* liking scrap wood projects. Any time I have a scrap length of ANYTHING left over I try to devise a project around it. :licking:
Regards,
Wrooster
10x16.5 Tire Assembly (A51039)
10x16.5 Tire...
Do-All Cultivator (A50860)
Do-All Cultivator...
1984 AM GENERAL HMMWV HUMVEE (A51222)
1984 AM GENERAL...
UNUSED Brown Metal Roof Panels (A50860)
UNUSED Brown Metal...
Chicago Air Tugger Winch (A50860)
Chicago Air Tugger...
2019 CATERPILLAR 326FL EXCAVATOR (A51242)
2019 CATERPILLAR...
