Caroni Flail Belt Failure
   / Caroni Flail Belt Failure #161
Ooops, on re-reading that I realize that I didn't tell it the way the jam happened.
In FACT I had stopped the tractor, shifted to PTO neutral, the mower spun down, I turned the tractor off.
I did some top link adjustment (hydraulic cylinder is off right now) and more belt checking.
It was when I next engaged the PTO that the tractor stalled.
Initially I didn't connect the fact that it had been running free and was raised when I stopped it, but jammed almost instantly when I next engaged the PTO. So I wasn't looking for a mechanical jam.
I don't have any temperature readings and since I didn't do any "before" measurements any "after" measurements would probably not be valuable.
I havn't done ANY calcns on this.
Right now I'm thinking that same tension force equals same tension force and with the same coefficient of friction the grip should be the same, regardless of wrap length or area.
My intuit says otherwise and it does seem to work well.
The cover is still off, I have only mowed short test strips.
Not clear when I'll get back to mowing for multiple hours on end, but when I do it will be with the cover on and I'll try to remember to do the "does it boil spit ?" test every 1/2 hour or so.
   / Caroni Flail Belt Failure #162
Alright, it's mowing season again, did anything ever come of this?
   / Caroni Flail Belt Failure #164
Did you switch back to the stock spring? She's just a hot one?
   / Caroni Flail Belt Failure #165
I will. I haven't yet because it hasn't made any difference. The stock spring is sitting on my workbench and asks me each time I go in there when I'm going to get off my lazy butt and put it back where it belongs. Next time I pull the cover I'll put the stock spring back on.
For those who don't know what I am talking about, we thought some of the mowers were running hot last year and that the reason might be a weak spring on the tensioning roller. Turns out the temp was identical with either the spring or a solid connection so I'm going back to the stock spring.
   / Caroni Flail Belt Failure #166
I just came in from using my rears for 2hrs. You can hold the pulleys tightly for several seconds. Im guessing 120F or thereabouts. No idler on these. You move the pulleys apart to tension.
larry
   / Caroni Flail Belt Failure #167
I checked mine today
my belts were 185
the top pulley was 185
the bottom pulley was 165
the idler was 130
and the gear box was 165
FYI i cut with the guard off so i could watch the belts.
What i would like to know is if instead of an idler pulley that has spring tension on it, would it be better to have a groved pulley in its place?
so instead of the idler pulling inward you would use a solid thread rod, put the adj. nut on the other side of the. . . i don't know what you call it but the little metal tit that the thread rod goes through and the nut sits on top of to keep tension on the spring. any way put the nut on the other side replace the smooth pully with v grove pulley and push outward.
it seems to me that there would a lot less drag on the belt and that it might help keep it a little cooler.
I don't know if i was clear enough for ya'll to under stand but if you did what do you think?
   / Caroni Flail Belt Failure #168
my belts were 185
the idler was 130
Why not look for a heat resistant belt?
   / Caroni Flail Belt Failure #169
my belts were 185
the idler was 130
I haven't looked back at the measurements I took last year but I think they were similar. I had also looked into what the permissible temperature range of the belts was and recall that these sorts of temps were actually OK.
I haven't had any trouble with my belts and am now in my third season. That includes stalling the tractor on several occasions and also mowing heavy June grass (4ft) as well as brush. I don't claim to know what is best here but I am planning on leaving well enough alone.
I had another belt failure. I believe this to be my fault due to over greasing. The picture understates the amount of greasy gunk that I found.
I will cut back greasing from every time I cut to every other cutting. I give 2-3 pumps per zerk.
I prefer to replace belts to replacing the main rotor.
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
2012 TEX MEX TRAILER LOW BOY GOOSENECK (A58216)
2012 TEX MEX...
Case-IH 4 Cylinder Power Unit (A57149)
Case-IH 4 Cylinder...
LOT: Better Built Heavy Duty Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Better Built...
2013 Yamaha YDREX4 Electric Golf Cart (A56859)
2013 Yamaha YDREX4...
(INOP) 2016 FORD F150 XL SINGLE CAB TRUCK (A51406)
(INOP) 2016 FORD...
