Mowing Caroni 1900 flail mower help needed
   / Caroni 1900 flail mower help needed #1
Trails End
Candia, NH
Bobcat CT335
I purchased my mower near the end of May and I
finally have my TM1900 set up and running. After
about 1 hour of mowing, I noticed that the shaft housing
between the gear box and pulley assembly was too hot to
touch. Is this normal? The mower appeared to be running
OK, with no excessive vibration, and I was running at the
recommended PTO speed of 540 rpm.
This is my first experience with flail mowers. I greased
all the bearings and the gearbox has gear lube. Oh, by the
way, the gear box still spews oil out of the vented cap.
I've ordered an extended adapter from British Metrics which
should take care of that problem.
Any help on the 'hot' shaft housing will be greatly appreciated.
   / Caroni 1900 flail mower help needed #2
Not sure if its related.....
Just purchased a Betsco flail mower. The directions said grease the upper belt shaft bearing till grease comes out, will take a lot.
I called and asked how much is a lot? It took close to 3 tubes of grease and of course it came out behind the pulley where you cant see it. Not at the shaft housing where the fitting is.
Had to pull the belts and pulley to get the excess grease wiped out. Alls good now and runs cool. The grease had to fill the shaft tube up.
This may be why yours is overheating.
   / Caroni 1900 flail mower help needed #3
Could also be why the gearbox is getting hot and boiling the gear oil out.
   / Caroni 1900 flail mower help needed #4
No clue, but if I get a chance to mow tomorrow I'll check.
   / Caroni 1900 flail mower help needed #5
I had a 1900 that I sold. It would leak oil even with the extension. I can't remember if it got hot, but I know my brush cutter gearbox gets quite warm especially if cutting heavy grass.
I had to mow much slower with the flail vs the standard brush cutter or I'd start smoking belts or just knocking the grass over. Are you pushing it hard? Do you have a laser thermometer to see how hot is hot?
I don't think I was pushing it that hard, with no sign of struggling with the engine. I do have an infrared thermometer and will
check on my next time mowing to get a better indication of how hot it's getting.
   / Caroni 1900 flail mower help needed #7
After 3 hours, the cross tube was only warm. I'd probably start looking at worn bearings or something. Just did 3 hours of mowing knee high grass. Still have more to go once I get repairs done. I damaged the PTO shield tubes beyond use. The top link pin fell out, and when I backed up, the tubes jammed together and are now nicely twisted together. I need to check if the actual PTO shafts are damaged as well. If they are good, I'll probably complete today's work without the shield.
   / Caroni 1900 flail mower help needed #8
If its just warm, it is probably fine. Painted surfaces can get too hot to touch just sitting in the sun.
   / Caroni 1900 flail mower help needed #9
I'm having the same problem with the same mower. Last year I replaced the belts and no change. Today I decided to try and trouble shoot. I greased all the fittings before starting and ran the mower for exactly one minute (no load). Took the belt cover off and found the idler was too hot to keep my hand on. So I removed the idler tensioner and checked the idler for signs of a worn bearing but couldn't find anything. It turned very smoothly with no signs of a worn bearing. I put it back together and used my Gates belt tensioner to check the tension. There are no specs That I could find in the owners manual or on the Caroni website, so I went by the Gates website, which recommended 150 lbs for a single belt (divide by 3 for 3 belts - so 50 lbs each). I set the tension and ran it again for exactly one minute and got the same results.
The inside of the belts are not hot.
The pulleys are not hot.
The pulley bearings are not hot and turn smoothly.
The back side of the belts are hot and the face of the idler is hot. This must be the source of the heat on my mower but can't determine what the cause is.
This makes no sense to me.
Maybe the OP and I are having the same issues
   / Caroni 1900 flail mower help needed #10
More info;
I ran the mower for 3 minutes at 540 rpm (no load) and got the following temps with an IR thermometer:
1) the back of the belts 165*
2) face of idler 131* but this is a shiny surface and I'm told the IR therms don't work on a shiny surface
3) inside center of idler 169*
The pulleys started to get warmer and the outboard end of the cross tube was starting to get hot.
The only thing I can think of that would cause this, is faulty bearings on the idler (but they feel fine) or friction between the idler and the belts. I did notice the idler was bouncing while running but not what I would consider to be excessive.
Not sure where to go from here.
More info;
Good idea, Hillbilly, so I did the same test after running the mower at full PTO rpm for 5 minutes.
Temperature readings were taken before engaging the PTO and then after 5 minutes with PTO off.
Back belt surface: 78 deg /120 deg
Idler inside center: 78 deg / 120 deg
Shaft housing: 74 deg / 79 deg measured half way between gearbox and pulley housing
Gearbox: 78 deg / 87 deg
All temps are in deg F
It appears that my temps were a bit lower after 5 minutes than yours after 3 minutes.
Not sure if we can make any determinations from that but it's there for whatever it's
worth.
I'll have to try temperature measurements after my next mowing.
   / Caroni 1900 flail mower help needed #12
I posted some more info about my mower, in the "Lets Talk Flail Mowers" thread, since I didn't want to hijack yours. Basically what I was looking for after running the mower for only a short time, was the source of the heat. After running it for the 3 minutes I took the belt cover off and felt around to find what was hot and what was cool. I found the idler and the back of the belts were hot but not the inside of the belts. Therefore it was obvious that the idler was causing the heat. Then I need to figure out why.
Here is part of what I posted in the other thread:
I then used the mower in ambient temps of 65* for about 45 minutes and it was raining. By the time I got back to the shop, grabbed some tools, the IR therm and got the cover plate off the belts, the back of the belts were 267* and the inside center of the idler was 269*. The outboard end of the cross tube was 141*. They cool down quickly, so I imagine the temps were even higher while operating the mower.
The source of the heat is obvioulsy the idler but the bearings feel fine. So either the bearings are not OK or there is friction between the belts and the idler, meaning they are slipping. But I can't see that being the case either.
If you check that thread you will see what I went through trying to get the idler to run cooler but have not yet determined the cause of the heat or the fix.
   / Caroni 1900 flail mower help needed #13
A belt relies on friction between the sides of the belt and the shives of the drive and driven pulleys to transmit power.
A byproduct of the fiction is the generation of heat.
The same holds true for a gearset. Transmitting power generates heat at the geartooth interface.
It’s physics.
   / Caroni 1900 flail mower help needed #14
It’s physics.
Of course it is but is 269* F is normal. I think not. Plus the heat on my mower is not being generated on the inside of the belts, where it rides in the sheaves, it is being created at the back of the belt where it rides on the idler. That is what I am trying to trouble shoot. If you have any ideas as to the possible cause of the excessive heat, they would be appreciated.
   / Caroni 1900 flail mower help needed #15
I'm normally not a big fan of 'shotgun troubleshooting', but in your case, it sounds like you've methodically narrowed down the source of the heat to one pulley. How expensive would it be to just replace it, to see if things improve?
For a totally non-tractor reference, my low mileage 2008 BMW 3 series was intermittently squeaking from somewhere under the hood. I used the old screwdriver-as-stethoscope trick & it seemed to come from the accessory belt idler. I replaced the idler, and when I checked the old one, the bearing felt perfectly smooth, with no dragging, and it didn't spin free like it was completely dry of lubricant. But...no more squeaking from the car. Sometimes a component won't exhibit a problem until it's truly loaded down in use.
FWIW,
Charlie
edit: I assume that you've checked to be sure that the pulley is aligned properly in the belt path, right?
   / Caroni 1900 flail mower help needed #16
FWIW,
Charlie
I've been away for a couple of weeks and haven't done any more since then. I did check out the pulley alignment previously and found it to be out slightly. I fixed that and the problem persisted. So I have decided to replace the idler bearings when I get time and will report back here afterwards, with the results. I think you are right. I can't see how anything else could be the cause, since the heat source is definitely the idler.
OP, have you fixed your problem and if so, how?
   / Caroni 1900 flail mower help needed #17
Update: I pulled the idler and got the bearings out with some effort. After cleaning them out in the ultrasonic cleaner I could clearly feel that both bearings were bad. I have new ones waiting for me in the big city and will have them picked up tomorrow. I am very sure this was the problem with my mower. It's odd that I couldn't feel anything wrong with them when they were in place and all greased up but it was very obvious when they were cleaned up.
I'll let you know how it goes after I get them replaced. However I will have to wait for my tractor to be returned from the shop. It was one of the Kubotas that was recalled to be split, to check for a possible improperly torqued bolt in the transmission. It left my place yesterday evening and I won't get back to this for at least another week or 2.
At this point, I'm still not sure if there is even a problem. I mowed for about an hour
yesterday, and didn't experience any problems. The area that seemed hot to the
touch after my first mowing was still hot but can't say whether it's too hot or not
at this time.
I mowed again today for about an hour, still with no apparent problems. The drive shaft
housing from the gearbox to the pulley enclosure was still hot to the touch. At this point,
I'm going to consider this normal.
By the way, I did receive and install the British Metrics extension on the oil vent and
sucess - no gear oil leakage today.
   / Caroni 1900 flail mower help needed #19
There is nothing wrong with your mower, as I have an Alamo Flail mower and it does the same thing. That is why the belts are Kevlar after all, because regular belts are just not going to cut it. If you buy autopart store belts, you end up putting them on one right after another because they cannot handle the rough service.
The gearbox on my PTO generator gets amazingly hot too.
If you are really concerned, you should affix a temperature gauge to the gearbox, and then run the mower. Right now you are just assuming it is running too hot, but what you really need to do is run it, and find out what temp it runs at, then if it gets above the normal operating temperature (which could be pretty high like on my PTO generator's gearbox), then you have a reason to be concerned.
   / Caroni 1900 flail mower help needed #20
What is the normal operating temperature range for your mower and for your PTO generator? Numbers please.
I am sure there is a range of temps that are considered normal but without the numbers there is no way to determine if your mower or mine are running at normal temps. My mower idler gets up to 270* and that temp was taken after driving the tractor back to the shop and taking the belt cover off. So I am sure the temp was much higher while the mower was being used. There was also a small puddle of liquid grease sitting in the recess of the idler pulley, which I believe was grease that got too hot. From what I found on the grease manufacturers website, that grease is suitable for temps up to 300*. So I am pretty sure my mower is running too hot. I will know better when I get my tractor back and can run it with the new bearings.
2012 DRAGON 130BBL VAC TRAILER (A58214)
2012 DRAGON 130BBL...
(2) 6 LUG WHEELS/GOODRIDE ST225/75D15 TIRES (A60432)
(2) 6 LUG...
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
(2) 330 GALLON POLY TOTES W/CAGES (A60432)
(2) 330 GALLON...
PJ  32 FLATBED GOOSENECK (A58214)
PJ 32 FLATBED...
2019 CATERPILLAR 950M WHEEL LOADER (A60429)
2019 CATERPILLAR...
