Carl
CRTMPRP
2012 MAHINDRA MAX 28XL HST
I have a 28 xl and can not get power to the switch key when it does it will crank and run for a while and then go dead but it will crank and run a while. Now I can not get any power to switch at all I have checked all the fuses and they are good. the only fuse that does not have any power is the fifty amp next to the starter. I have power to the QGS controller and at the main fuse in the fuse box. Where do I need to look for the problem now
Trace the 50 amp fuse wire back to the battery. Wire is broken or loose @ battery.:thumbsup:
/ Carl
the 50 amp fuse close to the battery is good it is the other 50 amp fuse and the wires go thru the firewall
2023 Case TV450B (A62177)
2023 Case TV450B...
WACKER NEUSON LTW20 LIGHT PLANT (A63569)
WACKER NEUSON...
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
2019 Jayco Octane T32H Toy Hauler (A62613)
2019 Jayco Octane...
2015 KENWORTH T800 HYDROVAC (A63569)
2015 KENWORTH T800...
2015 HYUNDAI HX220L EXCAVATOR (A64279)
2015 HYUNDAI...
